What brand and where to get one? Recommendation please
| Author | Subject: Replacement cambelt |
Matt_rallye
Regular Location: Bournemouth Registered: 09 Jul 2012 Posts: 468 Status: Offline |
Best place to get a kit? Need one as mines snappedWhat brand and where to get one? Recommendation please |
If yours has snapped you need more than a cambelt kit thats for sure!!!Presuming you know the head will need rebuilding as the valves and pistons will have hit each other? ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
yippeekayay
Seasoned Pro Location: wilts Registered: 27 Oct 2008 Posts: 4,144 Status: Offline |
get the head off and get it looked at an head engineering shop and check all the valves, also make sure your bottom pulley hasn't rotated so the timing marks are out. they are known for the rubber inside to move in relation to the outer steel pulley. You might consider an engine change as a cheaper alternative and sell your bits to get some money back. the last head I had done cost about 450-550 plus new belt... ________________________________________ 306 less for first time in nearly 7 years. Lets keep it that way... please refuse any offers i make to buy your 306 ( doctors letter supplied by request)Marmite and cheese sandwiches anyone??? Burns and Mcrae will be forever missed. x box "yippeekayaymofo" |
Valve guides and seats will need checking too As Andy says,not a cheap job if there is alot of valves bent Obviously you need to consider price of headgasket kit,labour too if you can't remove head yourself ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
Matt_rallye
Work will all be done by a few mates and me, I have a replacement head that's been rebuilt so should be all sweet, will get a replacement bottom Pully while I'm at it, maybe even upgrade it too a shiney one |
GSF ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Matt_rallye wrote: Work will all be done by a few mates and me, I have a replacement head that's been rebuilt so should be all sweet, will get a replacement bottom Pully while I'm at it, maybe even upgrade it too a shiney one ![]() Bottom ends have been kown to fail not long after a belt fail as well so be warned |
Matt_rallye
What on the bottom end would fail? Is going to be a "I may aswell replace the lot" |
Niall
Seasoned Pro Location: Epsom Registered: 06 Jun 2012 Posts: 1,941 Status: Offline |
Matt did your belt actually snap or did it just slip? From what I saw it had only slipped! |
Matt_rallye
Bender! I started this before I knew the details, it's a mega mash up to be fair. ![]() ![]() ![]() For anyone who hasn't seen the damage |
slipped/snapped, same difference, same damage!________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
