Author Subject: Car wont turn over
deanstacey
Right, fitted a stereo last weekend and the car wont start now! The head unit is the same as before but I fitted two amps in the boot, running two powerleads straight from the battery. Since this point the car wont turn over.
It will jump start and it will bump start.
There is 12.5volts across the battery
There are no fuses blown in the fuse box.
When I turn the key all the lights come on nice and bright and then there's a small thunk as the starter motor tries to engage and then nothing. This is not a meaty engaging thunk, just a small one. The dash lights are then dim.
Any ideas as my mates are getting fed up push starting me Smile
Posted 11th Jul 2012 at 21:37
Starter motor is done for bud
That's how mine went just died
Manifold off to change it Yes
Posted 11th Jul 2012 at 21:42
deanstacey
Thanks Chris
Why would it start when it's jumped from another car?
Is there a way of testing a starter motor?
Posted 11th Jul 2012 at 22:26
No idea dude ?
Had a similar problem ? Turned the key and it only made the noise of the starting motor firing but not turning ? I never tried the jump lead answer to be honest ? Just whipped the manifold off and changed the starter - problem sorted Yes
Bite the bullet dude get another starter Yes
Posted 11th Jul 2012 at 22:35
It won't be the starter if it will turn over fine when given power from another car...
For whatever reason your battery is not providing the correct current to the starter to enable it to engage and start to turn. A stalled motor takes a very high current to start to turn. If you have your ICE system powering off the battery constantly then the battery will not have enough power left to turn the starter. However,when you connect another car's battery to it (which is running) you have a lot of current available and the starter has enough to turn...
I believe the problem you have is caused by the fact your amps in the boots are powered directly from the battery. Try putting them on a switch, so you can switch them off before trying to start the car and I suspect your issue will disappear. Yes
Posted 12th Jul 2012 at 07:16
blandy
You need to do a Drop volt test on the battery to see its condition as the battery could be old and weak and the extra current to the amps has finished it off. Put a multimeter across the terminals whilst someone try's to start it. You should have more than 9v when cranking of not the car won't have enough power to turn over hence why jumping works. If the amps are wired correctly they shouldnt really cause a issue as they turn off with ignition off but double check they do
Posted 12th Jul 2012 at 07:30
deanstacey
Cheers guys.
Just went out and removed cable by cable from the amps and tried to start it after each, nothing. Removed the head unit and disconnected the amp remote ( which fires up the amps when the HU is turned on), nothing. Disconnected the main fuses in the power leads to the amps so that there is now nothing new running on the car. Nothing.
Now it gets weird. I put the meter across the battery and had 12v. Put it on the windscreen so I could see it as I turned the ignition switch to do the drop test, turned the key and bugger me if it didn't start!!!
Reconected leads one at a time to see if I could identify a dodgy lead, and everything is fine. It started first time, every time ( the battery started the car about 15 times in a row so I'm guessing it's good)
Not quite confident to leave the jump leads behind, but things seam to be sorted.
Thanks for your help.
Posted 12th Jul 2012 at 09:37
smithers
Positive terminal not getting a good connection after nannying about with the AMP power leads?
1997 Black GTi6
smithers205 at hotmail.com
Posted 12th Jul 2012 at 10:58
Exactly my thoughts after the above post. Yes
Posted 12th Jul 2012 at 11:16
deanstacey
I didn't touch the terminals today other than to put the meter across them. ( The power leads to the amps have fuses so I removed these to isolate the supply to the amps)
I have a friend who repairs and builds power supplies looking at it tonight to make sure everything is drawing the correct power, but for now I'll settle with it starting whatever the reason.
Ta
Posted 12th Jul 2012 at 14:42
