Author Subject: S16 alternator mount
need an S16 auxiliary bracket, basically the lower part of the engine mount which attaches to the block which the alternator mounts on. cheap please LOL
Posted 4th Jul 2012 at 14:03
anyone? miles maybe?
Posted 7th Jul 2012 at 23:55
bump..
Posted 31st Jul 2012 at 09:28
miles
Just scraped one the other week, but with the S16 one you need a steel sump or get grinding.
www.pugracing.com
Posted 31st Jul 2012 at 14:56
i've put a thread on drivers, so in middle of trying to sort it. i never realised the s16 alternators were different to the gti6. i've hassled colin satchell into making me another one of these:
so i can't use the full s16 setup. i have a gti6 alternator here, so naturally i'm annoyed. i might see if i can make something for mounting the alternator on, like a bit of thin bar and lug with a tube to run a bolt through. we'll see
Posted 31st Jul 2012 at 15:03
you still need the alternator mounting if you use the satchel upper mounting, as miles said you need a steel sump usually.
DCC has all you will need.
Posted 31st Jul 2012 at 16:35
he'll only sell the kit complete though, the top mount is no use to me
we're hopefully going to fabricate a proper lower mount at weekend for the gti6 alternator, will report back!
Posted 31st Jul 2012 at 17:26
i reckon if i just cut the bottom ~50mm off the std gti6 one which retains the alternator mounting lugs and the 2x bolt holes into the block, then use rosejointed adjuster on a colin satchell topmount, then that'd work fine.
Posted 31st Jul 2012 at 22:40
