Author Subject: Vibration From Rear Brakes
inviroman
This is a strange one!
When braking at speed on the motorway i have a vibration from the ear brakes, if i pull the handbrake when at slower speed the vibration is worse and have a knocking from the NSR wheel, seems like it is locking up? ABS???
Checked rear mounts and all parts on the rear and all seems OK.
New discs and pads was fitted around 1000 miles ago and quality parts used
Any ideas.
Cheers.
Project Diablo, in the making,Ready 2013 Smile
Ex Blaze P2 6 Owner, the first and will be missed Sad
Current Scooby STI Owner Big grin
Happiness is not always getting what you want!
Posted 15th Jun 2012 at 10:10
Have you jacked the rear up and had a good look round like spinning the wheels and looking for any signs of wear anywhere?
How exactly did you check "all parts on the rear"?
Posted 15th Jun 2012 at 10:29
smegal
Are the right angled thingies that hold the pads in fitted correctly?
Ex SC-6
Now in a Megane R26
Posted 15th Jun 2012 at 19:54
inviroman
Checked all the rear components and all is fine,no loose bolts or any parts that seem out of place.
one thing id did find was the rear brake compensator was seized? freed this off but it seems that there is a part of it missing?
On the photo below it shows the top white plastic part which i have missing, is this to be on the car or removed when fitted?
It seems that there is nothing to pull the compensator when the suspension goes up and down.
inviroman has attached the following image:
Posted 19th Jun 2012 at 11:50
smegal
If you're talking about the part with the arrow. It is for shipment and is not important.
Ex SC-6
Now in a Megane R26
Posted 19th Jun 2012 at 12:03
inviroman
Cheers,
Can you get the arm and spring only? mine looks a bit worse for wear!
Not had a chance to test drive the 6 yet but i my need new rear callipers as the bleed nipples are solid
Posted 23rd Jun 2012 at 20:04
