Author Subject: STOP light coming on :/
lost4words
Hi all,
Well today whilst leaving work my STOP light decided to come on... now being paranoid about my french piece of... i duely stopped and turned the engine off for a min or two... turned engine back on and stop light was off so all seemed normal... carried on driving for no more than a couple of mins and stop light came back on... this time i was at some traffic lights and the car was idling - it didnt seem to be idling some, some slight judder so i thought oh dear and headed towards spoox in leicester as they are nearer from work than my home/carls...
stupid piece of french, its asif it knew this! and magically the stop light went off! i thought stuff it and carried on and got to Spoox, told them the problem, they said it was either the oil, a sensor or something else. Checked the oil and all is fine. Pulled off the sensor (blue one) and had a quick look at it and put it back on. Started her back up and no problems again.
I was advised keep an eye on it and if you hear the engine being noisier than normal then get it looked at. Drove home and no issues.
Got back in the car about 2hrs later and drove to my mates to go football, picked him up and then when i was at the traffic lights stationary again the stop light came back on and the car again wasnt idling right. This is then where it gets weird as the stop light then decided every couple of seconds to go, on off on off on off.. etc and this carried on happening for the next 2/3mins. By the time i was at football about 10 mins later again all fine. Parked up at football and left the car a few mins then went back and had to move it as i was blocking someone in, once i had moved it and about to turn the car off. Magic, on again comes the stop light and wierd light juddering/funny idle.
Drove to my grand parents house after football. Rechecked oil again. All fine. Started up to leave and stop light stayed on for about 3 more seconds than normal and i got the strange idle again but them it went off all fine.
Just drove home (about 5/10min drive) no issues at all.
Any help would be greatly appreciated Smile I have had nothing changed recently on the car. Used the car all weekend as was fine. Temps normal etc.
Appologies for the essay aswell! LOL
Team 'No Longer A 306 Owner'
Team 'VTEC'
Black Honda Civic 'EP3' Type R
Moonstone 306 Gti-6 - Died at 82k
Black 306 HDI - Sold 08/08/2010 at 102,229
Posted 13th Jun 2012 at 22:05
If it wasn't idling correctly could be a coil pack or spark plug failing...
Posted 13th Jun 2012 at 22:11
lost4words
Its not a really bad idle tho its just not its smooth self and then goes back to normal. Its like a really light juddery effect. If you get what i mean?
Team 'VTEC'
Posted 13th Jun 2012 at 22:18
STOP lights have been to known to randomly come on when there have been cooling fan issues, like a dodgy sensor or Bitron unit. Yes
Try unplugging the brown sensor on the thermostat housing with the ignition switched on and make sure both your cooling fans spin up. If they do, put the plug back on and see what happens. A loose connection on this plug will give you a STOP light fault. Yes
Posted 13th Jun 2012 at 22:25
lost4words
ill try that tommorow then. Any other tests I can do?
Team 'VTEC'
Posted 13th Jun 2012 at 22:28
You could disconnect and reconnect the Bitron unit...
This is a little more difficult as it's underneath the passenger side wing, and you will need to remove the NSF wheel and arch liner to access it, but it's not that hard. Wink
Posted 13th Jun 2012 at 22:37
stuttering idle could be a lambda sensor.
Posted 13th Jun 2012 at 22:52
Was it raining by any chance ?
Ill put money on it being the bitron unit playing up and causing the fans to come on for no reason causing funny idle Yes
Posted 13th Jun 2012 at 22:57
lost4words
i think bigbadbowen could be right... came home this evening and fans came on bout a min after i had started the car... so couldnt of been cus it was hot!
Team 'VTEC'
Posted 16th Jun 2012 at 21:48
Yep, sure sounds like the Bitron unit playing up. Yes
Posted 16th Jun 2012 at 23:10
lost4words
Any ideas roughly how much to replace?
Team 'VTEC'
Posted 17th Jun 2012 at 06:57
mechanical_repairs
I can supply and fit a brand new bitron unit for £65.
Carl
Posted 17th Jun 2012 at 08:32
lost4words
Do you think thats the issue then Carl?
Team 'VTEC'
Posted 17th Jun 2012 at 17:55
I'm of the opinion it is probably the culprit. Yes
Posted 17th Jun 2012 at 19:27
lost4words
Do i get a money back guarentee? Wink
Team 'VTEC'
Posted 18th Jun 2012 at 21:46
LOL
Not from me, Carl might do one though.
Posted 19th Jun 2012 at 06:48
cescnathan
Totally agree with Stan Yes , the Bitron unit.....
Posted 19th Jun 2012 at 09:40
pugjim
I have had a similar problem in the past and it was the brown temp sensor.
Posted 20th Jun 2012 at 07:55
teo79
I would try an engine flush with a can of wynns oil flush then oil and filter change first you could have a blocked oil chanel causing a drop in oil pressure
tjones
Posted 1st Jul 2012 at 01:56
