Author Subject: 184119 Do I need it?
smegal
Number 2
Listed as "suspens Washer". I have the feeling that it is the threaded part in the chassis.
Ex SC-6
Now in a Megane R26
Posted 12th Jun 2012 at 00:38
Rich E Forum Admin
No, it's just a large washer that sits between the engine mount and the chassis cradle.
Posted 12th Jun 2012 at 01:06
smegal
Is it importan? On mine I was greeted by bad welds that took ages to grind flush with a dremel.
They're on back order and only sold in packs of 4
Ex SC-6
Now in a Megane R26
Posted 12th Jun 2012 at 01:08
smegal
Just bought some M10X50 washers. Will make them fit with a grinder if needs be.
Ex SC-6
Now in a Megane R26
Posted 12th Jun 2012 at 01:16
It should be there Craig, after all Pug wouldn't have gone to the trouble of fitting one there if there wasn't a reason for it. Wink
Posted 12th Jun 2012 at 06:27
smegal
Cheers Stan and Rich.
Ex SC-6
Now in a Megane R26
Posted 12th Jun 2012 at 08:36
No problem, I believe its actual purpose is to evenly distribute engine load over the cradle to try to put less stress on the threaded part of the mount/cradle. Doesn't seem to stop a lot of them cracking though. Sad
Posted 12th Jun 2012 at 09:36
I'm pretty sure in Daveyboy's thread on his repairs to this area he recommends leaving the washer outDunno
As the base of the mount is a bigger surface area than the washer,so the mount straight onto the metal spreads the load over a bigger area than having the washer fittedThumbs up
Posted 12th Jun 2012 at 21:34
Fair dos I suppose if that is indeed the case. Seems odd though as Pug went to the trouble of fitting it there? Dunno
Posted 13th Jun 2012 at 22:13
aaron6
He leaves it out to compensate for the height difference. Id imagine its there to allow the mount to be turned without picking up on the cradle. It also gives a flat surface to seat on thus redusing the likelyhood of it coming loose. Smile
Posted 13th Jun 2012 at 22:22
Makes sense to me. Wink
Posted 13th Jun 2012 at 23:00
