Author Subject: Increase rear brake bais
pugbug
I've had the car lowered and can feel the front brakes working a little too hard, my IR thermometer shows that too. Is there anyway of increasing the bias for the rear?
Posted 11th Jun 2012 at 19:48
scotzman
If its been lowered at the rear then the rear brakes should actually be working harder than usual.
Posted 11th Jun 2012 at 19:58
pugbug
^ Are you sure its not vice versa?
Posted 11th Jun 2012 at 20:28
darzmat
I would imagine they work harder when lowered too as the bias valve would effectivly thing there is more weight at the rear. I'm assuming that's how the bias valve works.
Posted 11th Jun 2012 at 20:37
thats correct, though might not be the case if its seized...
Posted 11th Jun 2012 at 20:40
smegal
If it has a compensator, you can change the length of the rod.
Ex SC-6
Now in a Megane R26
As Smegal says, the length of the rod can be changed if you have the compensator...
However, if the car is a Phase 3 then the rear bias is controlled by the EBD in the ABS pump, and there is no compensator present. Wink
Posted 11th Jun 2012 at 22:13
pugbug
dammit it's a p3 Sad
The abs kicks in too quickly and I feel as though the back brakes have a lot more to offer!
Posted 11th Jun 2012 at 22:38
s**t pads/tyres? incorrect tyre pressures? crap road surfaces?
Posted 11th Jun 2012 at 22:52
seized/crap rear calipersDunno
Aslong as the rear discs are not rusty and are shiny where the pad touches the disc I would not worry,they are working fineYes
Posted 11th Jun 2012 at 23:14
pugbug
Running 215/45/16 Falken Ze192's 33PSI(F) 31PSI® I've driven a fair few 306's most of the braking can be felt on the front but on this car, it's excessive for sure. Probably crap calipers, as mentioned, I'll wait for the new discs and pads to bed in and take it from there.
Posted 11th Jun 2012 at 23:26
fatlapit
mine locks the rears too mate makes it more "fun"
Posted 14th Jun 2012 at 10:24
