Cheers lads
| Author | Subject: Cam cover gaskets ?? |
Moonstone6
Regular Location: Lichfield Registered: 11 Apr 2012 Posts: 268 Status: Offline |
Hi folks are the rocker cover gaskets for our engines (XU10J4RS) available from pug or are they just a sealant ? I am changing my cam covers for some I have had powdercoated ?????? Cheers lads |
simonjames
Seasoned Pro Location: Whitland S.Wales Registered: 23 Nov 2004 Posts: 6,219 Status: Offline |
Sealant is all thats available ________________________________________ All South Wales Members Click HereTeam Supercharged Black RALLYE ™ (Click Here for Build Project) MY EBAY ITEMS 07943066306 |
The gaskets are bonded onto the covers,they are not available on there ownIts a right job to get the covers sealed if you have removed the seals alltogether ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
Good luck getting them sealed |
barnettjd77
Regular Location: dorchester Registered: 12 Nov 2011 Posts: 483 Status: Offline |
When i asked my pug dealer this they said it was a straight bare fit... thick fu**ers!!![]() The 5th attempt i got mine sealed. ________________________________________ A red rallye in progress! |
gnrlee
Forum AdminLocation: Leeds Registered: 20 Aug 2005 Posts: 8,891 Status: Offline |
I once discussed this with Pugjim,..Could a cast of the bottom of the cam covers Be made and Then make a gasket that would fit perfectly? ________________________________________ Proud Member of the ASTOR Owners Club |
Moonstone6
barnettjd77 wrote: Yea I can believe that mate they haven't got a clue about the real peugeots the just monkeys ain't they lol When i asked my pug dealer this they said it was a straight bare fit... thick fu**ers!! ![]() The 5th attempt i got mine sealed. |
Moonstone6
coskev wrote: Cheers mate ok il try some rtv sealent on them that's all it looks like anyway it's as if they apply a bead to the cam covers and allow it to cure slightly before fitting them The gaskets are bonded onto the covers,they are not available on there own Its a right job to get the covers sealed if you have removed the seals alltogether |
Moonstone6 wrote: coskev wrote: Cheers mate ok il try some rtv sealent on them that's all it looks like anyway it's as if they apply a bead to the cam covers and allow it to cure slightly before fitting them The gaskets are bonded onto the covers,they are not available on there own Its a right job to get the covers sealed if you have removed the seals alltogether The problem is the size of the gap you need to fill The cam covers do not go right down flat onto the cam carriers If you look at the part where the bolts go threw the cover they are lower than the outer surface where gasket sits,to stop the gaskets getting squashed too much by heavy handed monkeys,so you need a massive bead of sealant,which is hard to get right Bolt one of your new covers on to give you some idea of how thick a bead of sealer you need ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
