Author Subject: i need help please, track rod ends stuck
whibley
ive hit a bit of a problem, im trying to change my tre and the buggers will not undo ive tried heat but they are still stuck solid, Ive managed to turn it two turns and now it wont turn back Sad
what are my aptions any advice will be great
thanks jase
Posted 4th Jun 2012 at 14:45
Heat usaully gets them off.
Best option if they are well stuck is to buy some new track rods and fit them at the same timeYes
Posted 4th Jun 2012 at 14:56
russbez
if you are replacing track rods as well as the track rod ends, you might need new rubber covers
i destroyed mine when i attempted to change a track rod
usually heat is enough Shock
post 24 on my project thread might have a few helpfull pictures for you
My Rallye project thread
Posted 4th Jun 2012 at 14:59
whibley
ok thanks i have a spare rack ill see how how the rods come of
thanks
Posted 4th Jun 2012 at 15:11
smegal
Take your new track rod ends to the garage doing the tracking. Oxy-Acetylene soon gets them off.
Ex SC-6
Now in a Megane R26
Posted 4th Jun 2012 at 16:31
Had the same problem ended up changing the whole rack as it was fecked Yes
Posted 4th Jun 2012 at 16:39
Can distort the track rods too if too much heat usedYes
Posted 4th Jun 2012 at 20:48
tvrfan007
Unscrew the track rod itself from the rack and work on the bench with heat, penetrating fluid etc
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 4th Jun 2012 at 21:37
smegal
Does it matter if its getting tracked afterwards? As long as the threads are ol.
Ex SC-6
Now in a Megane R26
Posted 5th Jun 2012 at 00:53
I would rather have straight track rods to be honest, regardless of whether it was being tracked afterwards. Yes
Posted 5th Jun 2012 at 08:12
whibley
All done I just changed the rod its self in the end needed a new gaitor anyways so replaced the lot, I struggled a bit to get the old rod of for some reason
Thanks for the advice
Posted 5th Jun 2012 at 16:52
tvrfan007
Thanks to an idiot tracking the car who had no idea how to use the oxy-acetylene, and put far too much effort into trying to undo the seized TRE.
I'm Si btw Tee hee
Posted 5th Jun 2012 at 17:34
smegal
I stand corrected. Yeah, that is a bit distorted.
Ex SC-6
Now in a Megane R26
Posted 5th Jun 2012 at 20:13
teo79
thats bent to f**k new rack or rod if its possible
tjones
Posted 2nd Jul 2012 at 23:32
