Author Subject: Cam Belt
dan2315
just started to change the cam belt and found that the bottom pulley dont line up with the top pulleys, does that mean i need to replace the bottom pulley?
Posted 30th May 2012 at 20:20
You don't need to replace the bottom pulley if you know what your doing and know how to tiime these engines up without using the pulley as a guide.
Have a look in the FAQ section, there is a thread which details where to put the woodruff key on the crankshaft so the bottom end is timed up correctly.
However, if you're not comfortable with that method then just buy a new pulley. Smile
Posted 30th May 2012 at 20:23
720puggti
Not necessarily mate. As long as the rubber damper material is in good nick then it's safe to carry on use it.
I would mark the slipped pulley with some tip ex against another non-moving part while it's bolted to the crank. This way it ensures that when you're checking the timing after fitting the belt by turning the engine over that that belt hasn't slipped.
I would also mark the crank pulley (the actual gear/cog) against the block before you take the belt off using a bit of tip ex. That way you'll know if it moved while you were working.
Chances of the crank moving while you were working are slim, but you would want to know if it did.
Deepak Gohil
Posted 30th May 2012 at 20:27
The FAQ you want is under the title 'Cambelt Timing Guide' and it is located on page 5 of the FAQ section. Wink
(Can't do a link on my phone at the moment) Smile
Posted 30th May 2012 at 20:30
Personally though, Get a billet one Ninja
That way you are free of crank pulley related worries.
Posted 30th May 2012 at 20:45
The ones Rich W sells are top notch, lighter for less rotating mass and no chance of the pin hole slipping. Cool
Posted 30th May 2012 at 21:16
beez_neez_gt
Do you have to fit a new crank seal when fitting the billet pulley, like the fly wheel has to ?
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 27th Jun 2012 at 18:10
No, and neither do you need to fit a new crankshaft oil seal on the flywheel end when changing the flywheel either.
Obviously, if you take the gearbox off and the flywheel and find it's leaking then yes, but otherwise no. Smile
Posted 27th Jun 2012 at 19:16
beez_neez_gt
Ok thanks, when cam belt was being fitted i forgot about the new seal. I have heard of the fly wheel crank seal leaking after a light weight one was fitted.
The pulley crank seal was fine, no leaks, so i guess the seal will have to wait a few months.
Pug fee`ver,
Posted 27th Jun 2012 at 19:26
The crank seal leaking will not be down to fitting a lightweight flywheel. It will have been coincidental. Yes
Posted 27th Jun 2012 at 20:41
beez_neez_gt
Yeah sure, well while things are off then fitting a new seal both sides is generally a job worth doing at the time i suppose. I guess you never know when they might wear out.
Pug fee`ver,
Posted 28th Jun 2012 at 01:00
Yes, to be honest if you've got the gearbox, clutch and flywheel out it is worthwhile changing the seal as all of that will need to come off at a later date if it subsequently started leaking. Yes
Posted 28th Jun 2012 at 09:39
Getting back to the crankshaft oil seal behind the flywheel, given that it's such a pain to access I would always fit a new seal when changing a clutch or flywheel, for the tenner it costs it just makes sense.
Posted 1st Jul 2012 at 14:12
Agreed, it does help though if you've got the proper tool to fit it in to the correct depth. Yes
Posted 2nd Jul 2012 at 19:42
teo79
ive just bought a billet crank pulley from lynx for £87.50
tjones
Posted 2nd Jul 2012 at 23:27
I have a bearing/seal fitting tool which sits them just below flush, flush is ok but level is more important than flush.
Posted 3rd Jul 2012 at 11:28
jonnie205
if it were me i would buy a new pulley, or use a known good one to time it up. Tipex is not the best as it does not tell you if the timing was correct on the belt you took off.
Posted 26th Jul 2012 at 19:57
Not worth the risk of using a slipped pulley IMONo
Just would feel like a ticking bomb to me,just waiting to come apart and take your cambelt out for good measure!Yes
Posted 26th Jul 2012 at 22:18
