Author Subject: Charger inlet pipe diameter
allesclar
Hey all,
Hope you are all enjoying the weather.
As the subject says, i am looking to replace the silicon 90 degree pipe with a metal one and want to know what the diameter is of the charger inlet pipe.
I would get it off the car and measure but i am not at home atm.
Adam
Team allesclar ®
Posted 26th May 2012 at 22:41
simonjames
I have a straight silicone and the 90 alloy pipe work if your interested
MY EBAY ITEMS
07943066306
Posted 27th May 2012 at 16:07
allesclar
simon,
how much do you want for it? (just the alloy part)
would it be a straight swap over with my current 90 degree silicon pipe? obivously i need it to be the same size as the pipe work and charger inlet so i can put silicon pipe over and clamp it on.
Team allesclar ®
Posted 27th May 2012 at 19:33
simonjames
Its in 2" alloy pipe work, i had the 1 silicone at the intake the 90 alloy pipe with a 500-700mm (roughly) length on to a 45 silicone then the rest was alloy pipe in to the intercooler the intake side is all fine, i also have the charger side which was just a silicone on the charger but that side has been damaged as well as the intercooler, most/all clamps are mikilor as well i was wanting offers around £40 delivered for the lot but i could cut off what you want and send to you
EDIT :- Heres a pic of what i've got
I could send you the 1 length thats at the top of the pic or cut off the remaining to the intercooler (cut tight to cooler where number 6 is written)
MY EBAY ITEMS
07943066306
Posted 27th May 2012 at 19:56
allesclar
thanks simon but i will pass.
thanks though
Team allesclar ®
Posted 27th May 2012 at 20:55
simonjames
Posted 27th May 2012 at 21:02
allesclar
its just the pipe from the charger inlet to the piping is only a few cms etc and so i dont think its worth trying to replace the silicon with a tiny corner of metal alloy.
Team allesclar ®
Posted 27th May 2012 at 21:04
simonjames
is your silicon sucking in ?
MY EBAY ITEMS
07943066306
Posted 27th May 2012 at 21:09
allesclar
yes. i was going to have a go at pulling the main alloy piping in further in towards the charger inlet to be honest.
Team allesclar ®
Posted 27th May 2012 at 21:21
You can get around the problem of "sucking in" very easily and cheaply.
When I was low boost and had this problem, I went to a factors and bought a straight length of 2" mild steel exhaust pipe, cost about £4 I think. I then cut 2 or 3 "rings" off the end of it and inserted them inside my silicon hose. No more collapsing and the car ran much better. Smile
Posted 27th May 2012 at 23:44
allesclar
Stan,
cheers for that, but wont it be a faf to get the tubing in or is it a case of leaving the silicon on the intercooler piping side, pop off the charger side and slide the "rings" into the silicon piping and bobs your uncle?
If so how thick were they? i have looked and seen either 50mm or 51mm al, was going to go with the 51mm. Did you use the jubliee clips too to secure them in place? Do you have any of the said rings going spare? Smile
Simon, i wouldnt want you to cut up your piping for the sake of a few rings if you understand?
Team allesclar ®
Posted 28th May 2012 at 12:36
smegal
http://www.ebay.co.uk/itm/51mm-2inch-45-Degree-Aluminum-Alloy-intercooler-Pipes-Bends-Hose-/220970225952?pt=LH_DefaultDomain_3&hash=item3372da1120
There are companies that will custom make stiffer silicon bends as well. E.g.
http://www.derbyperformancehose.co.uk
Ex SC-6
Now in a Megane R26
Posted 28th May 2012 at 12:40
allesclar
cheers Craig.
but because i kept my air-con, it is a smaller but 90 degree silcon elbow. With only a little bit of space. i will draw and upload.
Team allesclar ®
Posted 28th May 2012 at 12:42
You mean like this?
Surely thats the charger outlet pipe?
I still need to sort mine out Doh
Posted 28th May 2012 at 12:49
allesclar
sorry guys but im at work and its blocking imageshack and images etc.
dont really want to go through a proxy at work either.
but i hope you guys can understand where im coming from?
Team allesclar ®
Posted 28th May 2012 at 12:50
allesclar wrote:
Stan,
Just remove the silicone pipe and push a couple up inside it in the middle of the pipe where you are getting the collapse.
I haven't got any left was over 4 years ago when I was low boost and did this mod. Yes
I think I made the rings about an inch long, no clips to hold them, just slide them up inside...Smile
Posted 28th May 2012 at 16:35
You mean the charger outlet pipe as your throttle body is on the inlet Whistle
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 28th May 2012 at 16:56
allesclar
ha true thanks Razz
well simon, if you are able to cut up a few rings about an inch in length i am sure we can sort something out Smile
Team allesclar ®
Posted 28th May 2012 at 21:20
allesclar wrote:
ha true thanks Razz
Cut an extra few for me please Smile
Not sure what I did with my spare bit of pipe.
Posted 29th May 2012 at 11:50
Have you got the "collapse" problem as well then Chris?
Posted 29th May 2012 at 23:07
