Author Subject: loose m5 bolt /timing belt damage
mjt4130
This happened today, reckon the belts slipped after this bolt was loose and got between a pulley and the belt, sending timing out and slashing the belt. Not sure if the head is s**teyed yet. I m thinking these bolts need loctite on them, check yours now!Cry
Posted 26th May 2012 at 21:46
Where i that bolt from ?
Posted 26th May 2012 at 22:32
mjt4130
the bolt is from behind the pulley, not sure what it holds
Posted 26th May 2012 at 23:30
Look like an inner cam cover bolt possibly, although it's so long since I've done a belt on a '6' now the memory is struggling a bit...
Posted 26th May 2012 at 23:44
I had the pulleys off my engine today whilst doing a belt change didn't notice any bolts up there ?
Posted 26th May 2012 at 23:53
miles
Yep, 6 bolts on the inner cambelt cover, mind allot of people don't use thread-lock when fitting them back in the head, A huge no no.
www.pugracing.com
Posted 27th May 2012 at 00:21
mjt4130
My head was rebuilt before I owned the car a few years ago. Getting my local garage to put a belt on and time it up, guess thats when I find out the bad news. The car is currently sitting on a ramp next to 3 escort rally cars, a classic 911 rally car and a 6R4. Will try and get some pictures next week.
Posted 27th May 2012 at 09:16
If the belt has slipped/jumped or come off you WILL have piston to valve contact. Yes
Posted 28th May 2012 at 11:22
mjt4130
So potentially, what would you do while the head was apart? Do these heads respond well to a bit of porting and polishing? Pre incident it was producing good power but if the heads being rebuilt how can I improve things? Dont want to change the cams and not intending on charging it
Posted 31st May 2012 at 20:48
They don't need porting, they flow extremely well as standard.
Just make sure when it's apart you check every valve and guide, get the head pressure tested and skimmed and a new set of valve stem oil seals. Yes
Posted 31st May 2012 at 21:21
honestly3k
I had a very similar problem to this after i drove my 6 home for the first time.
It sounded like a tractor and turned out there was a bolt wedged between the belt and the cambelt cover. It gauged out a line around the belt.
Apparantly a bolt or two got in with the camshafts too at some point and they had to be machined again.
But it somehow didnt damage the head. Sounds sweet as a nut and has done since.
Hopefully yours will have the same outcome
Posted 31st May 2012 at 22:08
mjt4130
The engines up and running! Just need to sort out an idling problem and its thereBig grin
Posted 20th Jun 2012 at 08:34
Had the belt slipped at all? Any damage? Dunno
Posted 20th Jun 2012 at 10:13
mjt4130
No damage to head but they cant get it to idle, which is strange as it idled perfectly before
Posted 24th Jun 2012 at 13:21
Probably a sensor which hasn't been plugged in somewhere when putting it back together...Yes
Posted 24th Jun 2012 at 18:48
mjt4130
Downer. Its a tapper! Still goes like a rocket but its got a very distinct tappety tap noise. Think I ll get it rebuilt over winter and risk it for now. Gutted.
Posted 1st Jul 2012 at 13:44
