Author Subject: What are our wheel bolt thread size?
so settled on the 16" Superleggera's after always running 15 or 17's
now after a bit of light reserach was under the impression that the wheel bolts I needed we M12'm
bought a 45mm bolt for the rear and a 50mm for the front
finding them hard to get in found that this happened to the longer bolt
and damaged the thread,..
on comparison to the cyclone bolts the thread is much closer together so what bolt size do I need for the correct thread size?
Posted 23rd May 2012 at 15:18
arhh just found that i bought the M12 x 1.5 but there's also an M12 x 1.25 <-- is that the correct one?
Posted 23rd May 2012 at 15:22
simonjames
Was going to say the thread looks a bit course on that, hub end damaged ?
MY EBAY ITEMS
07943066306
Posted 23rd May 2012 at 15:24
stu
M12 x 1.25 is correct. Yes
At least, that is what I was told when looking for a set of locking wheel bolts.
Posted 23rd May 2012 at 15:27
no gave it a good clean before hand, that's copper grease on the bolt
the cyclone bolts are strait in no problem!
I think that my problem is I got the 1.5 thread when i should have gone for 1.25
i'd like to go hub conversion with the anodized blue looking wheel bolts like on yours but not sure how to measure up for them?
Posted 23rd May 2012 at 15:29
beez_neez_gt
Yes M12 1.25 is the correct thread pinch, try rally design for bolts.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 23rd May 2012 at 15:44
simonjames
Try this guy
http://myworld.ebay.co.uk/tonto100_0/?_trksid=p4340.l2559
He used to be on here Tonto had a white rallye he does stud/nut conversion kits, im sure i saw a set up 1.25 to hub 1.5 nut etc etc
MY EBAY ITEMS
07943066306
Posted 23rd May 2012 at 15:53
send a tap through that drive flange before fitting a bolt in there, and cross your fingers there's enough meat left.
and also pray that you haven't fitted all 4, or the other 3 wheels...
Posted 23rd May 2012 at 16:44
Their fine!
the bolts were softer than the thread on the hubs
I checked all that afterwards!
Like I say the cyclone bolts went in fine after and I only bought 1 of each bolt to test my measurements
Mite be worth sending a tap through if only to get all the old rust and crap out! Thumbs up
Thanks a lot guys! Thumbs up
Posted 23rd May 2012 at 17:23
right need your help again guys!
i'm thinking the hub conversion route is the better route to go down,..
due to being easier to get the locking wheel nuts for them
it can be done but £50+ on just standard wheel nuts + locking is a bit excessive! Dry
so in the standard wheel nuts that fit are 45mm and 50mm M12 x 1.25 thread tapered
do I get the same 45mm and 50mm versions like this one ( 50mm )
or do I have to allow extra length for the size/length of the Lug nut to fit onto as well?
if no one can answer i'll give them a ring tomo!
Posted 23rd May 2012 at 19:49
If your fitting open ended nuts you can go abit longer on the studWink
If they are closed end nuts you need to measure up correctly.
When I did it on my 309 I put the wheel on the car,then just stuck a tape measure through the bolt hole upto the hub faceBig grin
Then ordered studs to fit.It does depend on the length of the nut you are planning on using thoughYes
Posted 24th May 2012 at 21:20
cress87
But surely this conversion kit with the studs and nuts plus the cost of a set of locking nuts will equate to more than £50?
Posted 24th May 2012 at 21:40
