Author Subject: Standard Airbox Query
Lecktorious
aka G.
Hi all,
I'll shortly be refitting the standard air box in my GTi 6. As it's had a K&N cone filter fitted since I purchased the car I'm not sure if I am missing any parts Dunno
Air box, lid and seal
Resonator box
Plastic neck
Filter (obviously)
Is there anything else I will need and how is the air box mounted in the engine bay? Does it bolt straight onto the inner wing? Had a look online for some pictures but no joy. I'm not sure what the plastic neck thing is for either?
I also have this problem...
Two of the studs that the resonator box have sheared. They can be bought new from Peugeot though...
Are these tack welded in place, or should they come away with a bit of brute force?
Any help is appreciated.
'98 Nile Blue 306 GTi 6
Posted 21st May 2012 at 21:17
scotzman
I think the studs are part of the housing so I think you're snookered there (drill them out and use bolts), the plastic neck slides in the top into the centre of the filter and the whole thing bolts on with two studs on the housing through the inner wing beside the horn and one bolt up into the chassis leg.
Posted 21st May 2012 at 21:43
Lecktorious
aka G.
It's the studs for the resonator box, even still if I drill them out I'll ruin the finish on the powdercoat. There shouldn't be too much weight from the resonator box resting on them anyway. Now where's that superglue...
Posted 21st May 2012 at 21:48
scotzman
Mine looked much nicer when it came off the Rallye Smile, you can just about see the plastic neck ( the oily thing at the top)
Posted 21st May 2012 at 21:53
How pleasant...LOL
Posted 21st May 2012 at 21:56
sod the resonator thing off Thumbs up
Posted 21st May 2012 at 22:45
Lecktorious
aka G.
What's it for anyway? Other than the last resting place of a sparrow, as I found out.
Posted 21st May 2012 at 23:05
It is supposed to smooth out the air pulses, a bit like the resonator box underneath the inlet manifold. Yes
Posted 22nd May 2012 at 06:22
to quiten down the intake noiseThumbs up
Posted 22nd May 2012 at 12:33
Roll eyes
That's another factor, which is why you get a lovely loud intake roar when people put on an open K&N filter. Cool
Posted 22nd May 2012 at 13:05
Lecktorious
aka G.
stan_306gti6 wrote:
Roll eyes
I'm taking the K&N off, too many puddles up here LOL
Got some new bolts and nuts ordered up for the airbox - if anyone can confirm if they are tack welded in place or not that would be helpful Wink
Posted 22nd May 2012 at 13:31
spot welded studs
Posted 22nd May 2012 at 13:43
Lecktorious
aka G.
spot welded studs
Cheers Welshy Wink
Hopefully the heat from the drill will break the weld...will soon find out.
Posted 22nd May 2012 at 13:55
a drill bit is meant to remove material not heat it up!
Posted 22nd May 2012 at 14:03
Lecktorious
aka G.
If you have any other suggestions for removing the remaining stud, post them up Wink
Posted 22nd May 2012 at 14:05
yeah, use the drill properly Razz
Posted 22nd May 2012 at 14:07
Laugh my ass off @ that!
Posted 22nd May 2012 at 14:22
