Author Subject: oil vapour hose
barnettjd77
I have had a search and there is not a page on it.
How do you remove this? got one coming and need to replace as part of my oil problems. Smile
A red rallye in progress!
Posted 19th May 2012 at 10:42
which one?
typically, remove any clips and give it a good tug.
Posted 19th May 2012 at 11:07
which one?
+1
Are you talking about the one that's got the little filter in it?
Posted 19th May 2012 at 11:42
barnettjd77
Noo the one that goes down onto a big pipe under inlet manifold, the right one of the two on the rocker cover
Posted 19th May 2012 at 16:07
That one is only a short pipe, which joins up with a system of other pipes lower down.
Peugeot only sell the whole lot complete, but if it's only the top hose you need, buy the whole lot and then just unclip and change the top one. Yes
Posted 19th May 2012 at 18:59
barnettjd77
I bought the whole complete lot Yes only because when i removed that top one you are on about i bloody broke the plastic bit on the other pipe which is joins to Angry
Posted 20th May 2012 at 00:34
ahh yeah done that myself LOL
manifold and starter off, maybe some of the wiring brackets too, iirc an 8 or 10mm in the middle of the plastic bit too? but it'll all become pretty clear once you have the inlet fanimold off Thumbs up
Posted 20th May 2012 at 00:48
barnettjd77
Was bloody annoying when I broke it.
Ah right bugger was hoping it'd be a quick fix but sounding not so much LOL
The top part was blocked up with s**t so prob a good thing I broke it to see all of it. Once new one on hopefully be all good. Yes
Posted 20th May 2012 at 00:57
As Welshy says, there are two 10mm nuts which hold the wiring bracket on under the manifold to the front of the block. You will need to remove the manifold and maybe starter then remove that bracket.
Once you've got that far, you will see the network of pipes and be able to unclip them and change the lot. Don't forget to order a new inlet manifold gasket for when you do the job. Wink
Posted 20th May 2012 at 07:10
barnettjd77
Well that's a ballache! i only put a new gasket on about 2 weeks ago LOL
still need to replace it? anything else while it is all in bits?
Posted 20th May 2012 at 09:48
You may be lucky and not *have* to replace it as it's fairly new. However, you run the risk of tearing the gasket removing the manifold and then being stuck without a car if Peugeot are shut at the time...
Shouldn't have to replace anything else whilst you're there though. Cool
Posted 20th May 2012 at 13:21
barnettjd77
Ah right why thank you Yes
I think getting one sounds a good option though after all they are like £3 something from pug anyway Smile
Posted 20th May 2012 at 13:22
Yes, perhaps at the same time as doing this job, you could combine it with fitting a PTFE inlet gasket as well?
If you are going to do that, you're best off buying two standard gaskets from Peugeot, so that you can put one against the head, then the PTFE and then the other standard gasket before fitting the manifold. Yes
This will give the best sealing, and it is how I have mine. Yes
Posted 20th May 2012 at 13:28
t3ora
Can I ask how much the breather hose was from pug
Road/track car coming together slowly
barnettjd77
It was about £44 i think i got a few other bits aswell but thought it was a good price Yes
Posted 20th May 2012 at 13:30
barnettjd77
Oh right ok then sounds good to me. What is the difference and where will i get a PTFE one to fit? long as it is not stupidly priced ha Yes
Posted 20th May 2012 at 13:31
"Phillip M" on here sells them, I think they around £10. Yes
The difference is that the PTFE is about 5mm thick and it doesn't transfer the heat from the head the inlet manifold anywhere near as much as the standard one does.
Ever been for a drive, then popped the bonnet and put your hand on the inlet? It's very hot. If you did the same thing with the PTFE installed it will be slightly warm, that's it. So the colder the temperature of the inlet air the better. Yes
Posted 20th May 2012 at 15:06
barnettjd77
I have messaged him and put ont in a wanted thread. thanks. Smile
I have done that yes, it is bloody hot haha.
I read on one thread here that it spaces the injectors or something... does that not cause any problems? mine is a standard engine
Posted 20th May 2012 at 18:25
Due to the gasket being 5mm thick (approx) it does indeed move the injectors further back from the valve ports. Yes
However, you will receive no problems with doing this, lots of standard '6's run these gaskets with no running issues whatsoever. Yes
Posted 20th May 2012 at 19:42
barnettjd77
Ah right ok then thanks.Smile
Are there any other advantages apart from the heat not transfering?
Posted 20th May 2012 at 19:46
It is said that due to the injectors being moved further back that the fuel gets more time mix with the incoming air therefore enabling it to atomise better, becoming a more combustable mixture. Yes
Posted 20th May 2012 at 21:24
barnettjd77
Ah right fair enough I see a few threads on them Smile shall give it a go as long as can get hold of one
Posted 21st May 2012 at 00:37
Just make sure you buy two standard gaskets from Pug and sandwich the PTFE one with them. This gives the best sealing then. Smile
Posted 21st May 2012 at 09:01
