Is this normal for my or any other setup?
Thanks andy
andrew315rawson@live.co.ukMoonstone phase 7 gti6
| Author | Subject: Fuel pressure regulator question? |
Hi folks, ive noticed my fuel pressure regulator making a hissing noise when I put the ignition on. Is this normal for my or any other setup? Thanks andy ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
that'll be the excess fuel returning to the fuel tank.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Sounds like air coming out or going in or air somewhere ![]() ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
stan_306gti6
It's so long since mine has run I can't remember if this happens to it or not. ![]() From memory, I haven't noticed anything untoward although like I say, I haven't used it for a while. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
not surprised with your exhaust stan ![]() wouldn't be able to hear myself think! ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
It can online heard when the ignition is turned on and the fuel pump primes up, it wouldn't be gear able with the engine running due to exhaust. ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
stan_306gti6
![]() I can't hear anything at all really when the engine is running, but I haven't noticed this hissing with the ignition switched on either. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Might be that Buzz's pump is on permanently with ignition feed rather than simply primes when turned to pos2.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
stan_306gti6
welshpug! wrote: Might be that Buzz's pump is on permanently with ignition feed rather than simply primes when turned to pos2. Possible, mine only works on Pos 2, although things like the AFR gauge work on Pos 1. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
No I think mine primes at position 2, that's what I ment when I put ignition on, I thunk________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
stan_306gti6
That is what is supposed to happen Andy. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
It's not the priming noise that I was wOndering about, it was the hissing/air sound from the regulator that I'd never noticed before________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
stan_306gti6
Have you made sure the retaining clip on it is tight?________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
the spring surclip type thing?It's either on or off isn't it that thing? It's probably normal and just something I just noticed ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
as I said before, its perfectly normal.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
stan_306gti6
buzzbrightyear wrote: the spring surclip type thing? It's either on or off isn't it that thing? It's probably normal and just something I just noticed Yeah, that's the thing I mean... ![]() Generally, it is an "on/off" thing, if you leave it off and prime the car, it generally fires out the fuel rail at high speed. ![]() I have never noticed this "hissing of air" before with mine, although maybe it is there and I've just not registered it. Can you hear it when you're in the car with the bonnet shut, or is it only apparant when you're under the bonnet and the ignition is turned to pos 2? ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
It's heard inside the car with the bonnet closed when you turn the ignition to no2, it lasts a few seconds and then stops. ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
stan_306gti6
Going by that description then, I've never heard anything like that coming from mine...Maybe you ought to ask Rich what he thinks as mine definitely doesn't do this. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
yeah Ill mention it to him when I see him, he's gonna think I'm a right hypochondriac ![]() ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
stan_306gti6
buzzbrightyear wrote: yeah Ill mention it to him when I see him, he's gonna think I'm a right hypochondriac ![]() You are the new "justinaccurate". ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
My exhaust sounds different aswell, it soundsLike its blowing but it's from the end of the tailpipe not further up the system. ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
stan_306gti6
That's weird as surely it must be difficult to tell if it's blowing from a place where the gases are supposed to be exiting? ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
