Author Subject: Heater dials
tarret
Hi,
I've got ph1 s16 dont have a/c and recently my fan blower dial has stopped workin, i still get hot and cold adjustment just no speed,
I've checked all fuses and I've tested the blower motor, I know there is a resistor could it be that? If so is it hard to change?
Can anyone help please
Posted 15th May 2012 at 20:36
FAQ maybe of use...
Posted 16th May 2012 at 00:12
tarret
Cheers I'll check it out Smile
Posted 16th May 2012 at 00:27
tarret
I've replaced the resistor, heater dials, I've checked the motor and fuses but it's still not working :/ anyone got any idea on what it could be?
Posted 20th May 2012 at 22:41
Is the speed control knob actually connected to the resistor behind? If it is slightly broken and you turn it, it will not operate the mechanism behind.
Best thing to do, is to whip the dials back out and check to see the resistance changes on the resistor as you turn the pot through its different positions. If that is all ok, then trace the wiring down to the blower motor to see where the problem lies. You should be seeing the same resistance at the blower motor end as you do at the resistor end if all is well.
Try using the control with no knob attached to see if the system is working and it is in fact the dial that's broken. Wink
Posted 21st May 2012 at 09:12
tarret
Ok cheers Stan ill have alook and see what's happenin Thumbs up
Posted 21st May 2012 at 09:26
No worries, have you got any further with this yet?
Posted 23rd May 2012 at 09:04
tarret
I've found that theres no resistance going to the dials so checked the wires well as much as I could see without pullin to much apart and they seem fine
Posted 23rd May 2012 at 09:38
