Author Subject: Warning lights on after a ph1 to ph3 seat transplant
milkyb
Got brave today and tried to change my seats. Took me a good few hours, finally finish, connected battery and alas I have messed up. The alarm is going off so I disconnected the wiring on the seat. The alarm has stopped however, there are now multiple lights on, I was expecting just the airbag light to be on.
Could anyone suggest why the other lights might be on, and what's the light just under the STOP? Have I incorrectly connected the seatbelt
pretentioners?
Thanks
Posted 12th May 2012 at 19:18
side airbag fault.
Posted 12th May 2012 at 22:08
milkyb
Not that one mate, that one is pretty obvious, the one above to the left of it, above the AIR LIGHt.
Posted 12th May 2012 at 23:29
Engine management light ?
Should go off when you start the car? Has nothing to do with the seats ?
Yes
Posted 12th May 2012 at 23:45
Yes
milkyb
I've disconnected the wires under the seat, so shouldn't there just be the airbag light on, why at there 4 lights on?
Posted 13th May 2012 at 19:44
Rich E Forum Admin
You need to plug the pre-tensioners in and start the engine.
Then look at what lights you have on.
Posted 13th May 2012 at 19:55
Light is on because there's a fault - the wires are disconnected LOL
engine light and stop light always on when ignition is on engine not running.
Posted 13th May 2012 at 19:56
milkyb
But these lights were on even when the selt belt pretentioners were connected. Cool. I'll re do the wiring and see if I ballsed up when originally connecting then. Thnx thus far guys
Posted 13th May 2012 at 20:56
do your new seats have side airbags?
Posted 13th May 2012 at 21:00
milkyb
No, that's why I only expected the side airbags light to be the only one that came on, even the alarm went off but I do think I must have shortcircuited somewhere.
Posted 13th May 2012 at 21:03
milkyb
Was just the wiring all, swapped the connections and now its only the side airbags light on. Woohoo. Time to drive the mother
Posted 17th May 2012 at 19:06
