Author Subject: High boost supercharged 6 engine with petert regrinds.
paul_13
I have a high boost engine which will have 87mm wossner pistons etc...
Now has anyone had experiences with running different cams on a supercharged engine?
Will be going for some petert regrinds. Stage 2 probably but worried about blow back on the overlap.
Any ideas?
205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit. Smile
Private work, not a prob Smile
Posted 10th May 2012 at 19:32
pugheaven
I have asked rich this before as I have another engine with a longmans head and piper 270h cams that I was thinking of using for my high boost engine, from what I remember he said it was pointless or something along those lines
Posted 10th May 2012 at 19:38
something to do with boost not having enough space to flow through properly or something?I cant remember either..
Posted 10th May 2012 at 19:53
matty_rallye
I was always under the impression that the cams wouldnt restrict a HB engine. Stan runs another 50 bhp over a HB on the standard ones i think.
2.1 16v 306 Rallye.
Posted 10th May 2012 at 19:54
Doesnt Garry have a cam in his 205?
Posted 10th May 2012 at 19:55
Is that the gentry one?
If so yeah I think so.
Posted 10th May 2012 at 20:01
simonjames
I had PT82s to go in mine but rich advised me that if anything i would probably have less power after fitting than if id just left standard cams in so i sold them on, but i'm sure iirc CAT cams do a pair of XU10J4RS cams that are designed for boosted engines but how good/bad they are on our charged engines i dont know
MY EBAY ITEMS
07943066306
Posted 10th May 2012 at 20:06
The accepted wisdom is, don't do it.
Posted 10th May 2012 at 20:12
paul_13
Ok, any reason why? Surely it will help to an extent. I'd like some solid proof really, not assumptions/guesses
Has Richw tried a supercharged engine on cams?
Posted 10th May 2012 at 20:18
The reason it doesnt work is that high lift, long overlap cams actually waste the boost. Rich has been through this and talks from experience. If you want better results, you need to consult your cam manufacturer and advise them that you are carrying out a forced induction build and let them spec the cams accordingly.
Posted 10th May 2012 at 20:26
paul_13
Spot on Smile
Posted 10th May 2012 at 20:41
gman
What the hell are you up to Paul. A high boost in your 205!! Beast!
I hope its not going to take up all your time - Miles is sending up the spare parts for the flywheel job, so hope you're still free for that. Need to get my billies on too!
1992 Onyx Black 205 GTI-6
2005 Honda S2000 (Sold)
2002 Audi S3 (Sold)
2005 Clio 182 Trophy (sold)
Posted 10th May 2012 at 22:44
This is correct. Yes
Posted 11th May 2012 at 01:17
rich_w
I have experimented with cams on the high-boost S/C setup.
It really depends what your aspirations are in terms of power, and where you want it.
They can give you a similar percentage gain as they would on a N/A engine. The issue is, the inherant nature of a centrifugal supercharger (like Rotrex) is to move the peak power / torque up the power band when compared to the same engine in N/A form.
This is becuase the impellor speed in the compressor increases with crankshaft speed - so boost increases as RPM does, so peak power is normally very close the the red-line.
Adding some higher lift and / or longer duration cams will move the powerband up the rev range further, which isn't always desirable.
I used a Cat Cams N/A grind on mine, and it seemed to respond very well to more overlap, due to the cylinder purging.
Smile
Contact Details:
07732 822546
Posted 11th May 2012 at 20:06
swiftyboi006
Say no more
Black p3 Love
Posted 11th May 2012 at 20:36
Really, as Rich says it's not necessary...No
If I can get 454bhp and 320ft/lbs out of standard cams, why on Earth do you need to swap them for something else?
Posted 12th May 2012 at 01:35
swiftyboi006
Stan says that he has a 6 with 454bhp but it appears to be non existant Dunno
Laugh my ass off
Black p3 Love
Posted 12th May 2012 at 10:33
Laugh my ass off
Laugh my ass off
It does exist I promise...Yes
Posted 12th May 2012 at 11:10
pete_rallye
Would you not benefit by fitting cams by bringing in the same amount of power lower down the rev range? As an eg. Rich's car is running~ 440bhp@ ~8300rpm rpm with standard cams. Whilst I owned the car, although it was ace, I thought it was too many revs for road use. I was thinking you could fit a different pulley to bring max boost in earlier, and a different set of cams to keep your 440bhp but bring it in at somewhere nearer 7500rpm. I don't think it needed any more power (well, maybe a bit more Razz), but the same power at less frantic revs would improve longevity and reduce the risk of your gearbox exploding.
Lap of the 'ring
Posted 12th May 2012 at 12:24
swiftyboi006
But like rich stated i dont think you can do this with a supercharger as it runs off the crank?
Black p3 Love
Posted 12th May 2012 at 13:00
dcc
SwiftyBOIIIIIIIII I think you missed the whole point of pete_rallye's post...
He suggests a smaller (I assume?) pulley on the charger. Its much like the gearing on a bicycle.
for arguments sake lets say currently the engine might only have to spin 1 turn but charger spins 2 times. however, if the gearing is changed, the engine now spins 1 turn and the charger spins 3 turns. you now have (for arguments sake) 50% more air being fed through the engine. This in turn gives the engine the ability to get more air in the chamber at lower revs.
My old g40 was running silly power from a very small engine (1.3) due to the charger putting out somewhere near 30 psi from memory (I think it was 2 bar).
205 GTI
Xsara HDI
Posted 13th May 2012 at 14:23
You could do this, but you would have to lower the rev limit to avoid damaging the charger...Yes
Posted 13th May 2012 at 15:22
pete_rallye
Yeah, that's what I mean. With the Rotrex charger you have to size the pulley to match your desired max rpm, so that the chargers maximum rpm limit matches your engines max rpm limit. With Rich's car this was well over 8k rpm, but personally I would prefer max power to come in around 7-7500rpm for road use. With the drop in revs will come a drop in power, despite the same amount of boost, so to help get the power back again, you could use a mild cam, giving slightly higher lift, but more importantly a bit more duration, giving the cylinders a little more time to fill. If you spec your cams carefully you should not lose any low down torque, and with the boost coming in a bit earlier, it should pull nicely from a bit lower down the revs also.
Lap of the 'ring
Posted 13th May 2012 at 20:01
Hmm more torque possibly?
Posted 13th May 2012 at 20:37
It's got me wondering that too. Yes
Posted 13th May 2012 at 22:44
