displaying posts 26 to 50 of 59
Pages (3): 1 [2] 3
Author Subject: Water Pump failure?
MCH_GTi6
formerly mch
ah I'm meaning a pressure test to see if its gone in the first place between cylinders...
Team Moonstone� Ph3 GTI6
Team Rallye
Posted 10th May 2012 at 15:02
Rich E Forum Admin
Sounds like it's gone between a chamber and a waterway, if it has gone.
Posted 10th May 2012 at 15:13
MCH_GTi6
formerly mch
so is it likely that it may be the head at fault then and I should get that checked?
I've got 2 spare heads here if it is a dud...
Team Rallye
Posted 10th May 2012 at 15:14
Rich E Forum Admin
No, the head's unlikely to be damaged. Mei's point is that you should have it checked over and pressure tested before having it skimmed.
Posted 10th May 2012 at 15:17
MCH_GTi6
formerly mch
ah ok, its a chap I know who will skim it so I'll ask him to check it all first
Team Rallye
Posted 10th May 2012 at 15:18
Does indeed sound like HG to be honest with those symptoms. Yes
Posted 10th May 2012 at 15:27
the pressure test I mean is done to a complete head off the engine, confirms the valves are seating as well as the cooling system is ok in the head.
Posted 10th May 2012 at 15:28
MCH_GTi6
formerly mch
Bit of an update...
Drained and refilled the system and bled it at the 3 points
Bulkhead by brake reservoir
Thermostat housing
Top of rad
LOTS of bubbles and air...
It now sits at below 70 for ages before slowly (very slowly) creaping to just past 90 and i mean slowly whereas when it happend yesterday it seemed to shoot up...
got to temp and fans kicked in and knocked it to just below 90 where it stayed and was barely creaping up at all...
BUT it does appear to be smoking (white vapour it looks to me) more than I think it should, my cat needs replacing though and that is a job I've been meaning to do and it is running rich due to this (decat and fitting kit ready to go on prob do tomorrow)
Team Rallye
Posted 10th May 2012 at 18:43
Rich E Forum Admin
The catalytic converter doesn't affect the fuel mixture.
Excessive steam from the exhaust is a tell tale sign of HG failure though. See what happens with the coolant now; if it's pressurising the coolant then you'll know about it very soon.
Posted 10th May 2012 at 18:50
Post #35
Leave it to get up to temp, and then switch it off and let it cool.
Come back to the car circa 8+ hours after it was last started, and remove the rad cap. You shouldn't hear a sound.
If you hear a big "hiss" or the coolant comes firing out at you, it's pretty much a guaranteed HG failure. Yes
Posted 10th May 2012 at 18:52
MCH_GTi6
formerly mch
Post #36
let it run for a while after bleeding and the level wasnt rising in the rad like it was before.
I will see what its like when I take it out next... if it gets hot I'll pull over...
I'll sort out buying the parts anyway as I get it all at trade so could flog it on if I dont end up using it all...
Team Rallye
MCH_GTi6
formerly mch
Post #37
Thought I'd go for a quick road test...
went up to 80 on the temp when following a van but as soon as I got onto "open" road again it went back to barely above 70...
Got dad to watch as I drove down the road after I'd got back before I put the car away and zero white smoke...
WTF that was all about I dont know, he forgot the compression tester (left it by his toolbox) but I'll get him to bring it home tomorrow just to double check.
Team Rallye
Posted 10th May 2012 at 20:42
Post #38
sounds like your stat is well and truly borked.
Posted 10th May 2012 at 21:15
MCH_GTi6
formerly mch
Post #39
I'll get a stat from the motor factors tomorrow... its only £7 so worth it for piece of mind
Team Rallye
Posted 10th May 2012 at 22:58
Post #40
just take the old one out and chuck it in a pan of boiling water and check the rubber seal on it
Posted 10th May 2012 at 23:08
fatlapit
Post #41
Just buy one they are cheap enough
Posted 10th May 2012 at 23:09
MCH_GTi6
formerly mch
Post #42
Dunno
Team Rallye
Posted 10th May 2012 at 23:21
Post #43
I wouldn't buy a stat from a factors to be honest...
I did this years ago as it was £6 against Peugeot's £18. It got stuck open after only 1000 miles and borewashed an engine. Sad
Got a replacement from Pug and it's been perfect, still running it years later in my current engine. Yes
Never again would I buy a thermostat from a factors...No
Posted 11th May 2012 at 01:23
MCH_GTi6
formerly mch
Post #44
Ok thanks for the heads up! Glad I checked here before going Smile
Team Rallye
Posted 11th May 2012 at 06:57
Post #45
Some items are fine from a factors, but in my experience a lot of the time if you buy cheap you end up buying twice. Yes
Posted 11th May 2012 at 10:21
MCH_GTi6
formerly mch
Post #46
more of an update...
Bleed the system and it behaves itself for a while...
but it doesnt last... I have noticed though the plastic housing just under the filler for the rad has split, its blowing air bubbles so could this cause air to get in and cause air lock?
I've not been using the car now. gonna see about getting the split plastic welded as its a nissens rad and its right on the join by the looks of it
Team Rallye
Posted 12th May 2012 at 10:49
swiftyboi006
Post #47
I think this is definatly your problem, it will be fine wen you bleed it for a wile. To be honest id replace the rad unless you can fix it good enough to hold pressure Thumbs up
Black p3 Love
Posted 12th May 2012 at 10:52
MCH_GTi6
formerly mch
Post #48
I have a standard Rad here that I'll put on this weekend...
Will see if i can get the other rad fixed... would be a shame to chuck it as its really good condition bar the bit where its obviously split (only knew as blew bubbles as I spilt a bit of water when bleeding)
Team Rallye
Posted 12th May 2012 at 10:54
swiftyboi006
Post #49
I think it will cure your problem, bare in mind the normal engine temp will be slightly higher than the nissens (i think)
Black p3 Love
Posted 12th May 2012 at 10:57
MCH_GTi6
formerly mch
Post #50
yeah I noticed a drop when I first fitted it...
Team Rallye
Posted 12th May 2012 at 10:59
Pages (3): 1 [2] 3
