Author Subject: brake bleeding?
jimmyhackers
i have replaced my rear calipers with recond ones. and bled the whole system (two man method). this all went swimmingly.
however the same problem remains, with the engine on the brake pedal has no pressure even at the very end but its does brake (stop the car) at the very end of the pedals travel (no feeling in pedal)
the same problem was there before with the original calipers but due to snapped nipples i assumed it was not bled properly.
i left the car sitting with no rear calipers on it for a few days and the system drained itself over that course, (could this be a problem?).
my questions are....... do i need to bleed the brakes while doing anything to the abs stuff? ive read a few people saying disconnect the abs ecu etc?
if not and its the brake servo that cream crackered. can i use the one from my 2.0 xsi?
thanks for any help in advance
Posted 5th May 2012 at 10:20
mr swampy s16
**BAD SELLER**
A lAck of servo makes the pedal very hard.
Try pumping the pedal when you brake, if they improve it points to the master cylindrr
Posted 5th May 2012 at 10:28
is your load compensator seized?
Posted 5th May 2012 at 10:36
fatlapit
Abs has nothing to do with it. its either brake servo or compensator. to test the servo. with the engine off pump the pedal until the pedal goes hard, when its hard keep the pedal depressed and start the engine. if the pedal does not depress further the brake servo is buggered.
Posted 5th May 2012 at 11:22
It will not have helped with the system completely draining of fluid.
You need to re-bleed them and starting with the rear calipers ensuring you have a hard pedal after each caliper. Then move onto the fronts. And use a clear tube for bleeding if possible so you can see any bubbles. Smile
Posted 5th May 2012 at 14:59
fatlapit
Or pressure bleed them
Posted 5th May 2012 at 15:25
jimmyhackers
i have a feeling my assistant (mate) wasnt up to scratch Sad i will try bleeding them again with a better one (dad) and see what happens.
if it turn out to be a faulty master cylinder or servo will the brake servo/master cylinder from my xsi be the same? its up for its mot in a month and between the two its the gti all the way.
Posted 5th May 2012 at 18:45
mc is gti/wallye specific and I would not be using an used one.
Posted 5th May 2012 at 18:53
ryangti6
No it's not, the late 1.8's had the same fitted as did the late 2.0 16 valve xsi's.
Also nothing wrong with using a used one aslong as you know it's good Imo.
Ryan
Posted 5th May 2012 at 19:58
tvrfan007
If the system has run dry and you've only bled on the drive you'll almost certainly have air in your abs - i'm not convinced this is the whole issue you have but will form a part of it. Find a loose surface and cycle the abs a number of times, then lock up a few miles (30 or so with lots of braking) then re-bleed.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 6th May 2012 at 05:11
jimmyhackers
well i left the two rear calipers off and the hoses drippign into pint glasses for about 3 days while i was away at work. might just need a re-bleed
Posted 8th May 2012 at 22:52
Blink
Why would you do that? You should of just left the lines screwed into the calipers until you had the time to bleed them properly. Yes
Posted 9th May 2012 at 00:03
