Platinum Silver GTI6 DOB friday 22/01/1999Xbox tag - pugway 306
| Author | Subject: Limp mode on 2.0 hdi |
scott-723
Regular Location: stoke Registered: 14 Aug 2010 Posts: 222 Status: Offline |
Hello iv just got meself a Citroen xsara hdi and it's gone into limp mode. Does anyone no how to bypass it cars working mint. No one can find a fault so I wanna bypass it if I can thanks________________________________________ Platinum Silver GTI6 DOB friday 22/01/1999Xbox tag - pugway 306 |
must be a fault or it wouldnt do it________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
tvrfan007
Seasoned Pro Location: In the garage Registered: 29 May 2005 Posts: 3,488 Status: Offline |
Limp mode will be there because of a reason, you can't just bypass it as it's not doing it just to play havoc with you. It will most likely be a fuel pressure issue, that's the main culprit for limp home mode. You will probably have a dying lift pump (tank pump), however you should have fault codes - if not then someone has been messing around with your ECU. ________________________________________ I'm Si btw![]() Night Blue VW Golf GTD Bianca LBSC Rallye - Track/Road Slag Project Thread Sparkling Silver Mini Cooper D - Super Dooper - (The other half's wheels) |
antcla.85
Senior User Location: Southampton Registered: 18 Dec 2007 Posts: 580 Status: Offline |
Boost temp sender? Sometimes on my engines they fail sending the wrong temp signal causing the engine to act as if in limp mode but actually its not boosting. Thats if they have them.________________________________________ Life is short, make it interestingBuy a Peugeot! |
pugjim
Seasoned Pro Location: Sheffield Registered: 11 Mar 2007 Posts: 1,380 Status: Offline |
You need the fault codes reading by someone who has diagbox/lexia. |
rob_humphrey
Regular Location: St Austell Registered: 16 Sep 2011 Posts: 448 Status: Offline |
Throttle sensor caused it on mine ________________________________________ Team Moonstone![]() Team Working Aircon |
