Author Subject: Quick harrness question
7057sam
Thursday i will be haveing some harrness points welded in.1 in transmission tunnel and modifing the sill point which is all ready they.
Question:As i dont have my subframes yet for the seats,but the subframes/base mounts use the same holes as standard seats.would i be safe mounting the point on the tranmission tunnel closer to the front or back of the seat?
I have seen a few pictures of the tranmission tunnel mounts and some differ quite abit
thanks guys
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 2nd May 2012 at 01:36
What kind of harness, and how many pointing points? If it's a five-point (i.e. with a bollock strap) I'd wait until you have the seats and frames to make sure it's perfectly central, as the seat isn't central to the mounting points.
Posted 2nd May 2012 at 09:21
If you have subframes, there will probably be a point to mount the harness to, there was on mine.
Posted 2nd May 2012 at 10:04
harnesses don't mount to the subframes, as owain said, hang fire till you have the seats mounted in the right place.
Posted 2nd May 2012 at 10:12
7057sam
Just opened up my new subframes to find they already have harness points on. so just got to the sort out the point on the sill tomorrow.
thank s for all you advice guys
Rallye dead Sad
Posted 2nd May 2012 at 19:07
There is a threaded seatbelt anchor point in the sill already if you have removed the standard belts anyway.
Posted 3rd May 2012 at 06:43
7057sam
yeah thanks guys all in now.just struggle to get out of them literally lol.
how do you remove the bit of metal from the sill anchor point,is it bolted on the othwr side ?
Rallye dead Sad
Posted 3rd May 2012 at 14:08
chris with a pug
its got a hook on one end. unbolt one end then pull in towards the center of the car and it will come out.
Posted 6th May 2012 at 18:58
7057sam
Cheers chris Smile
Rallye dead Sad
Posted 7th May 2012 at 02:18
