Author Subject: TSW's and a repetative noise
m1kee
Recently purchased a set of TSW's and tyres from ebay, bought some tappered wheel bolts to suite
I started to get a revolving type rubbing noise which felt worse on braking but also like a balancing problem at 45-50mph
Dropped into my friendly garage and they said they could not find anything wrong, though they only had a quick look there was nothing that would fail an MOT
I told them what I had done and they said the bolts might be slightly too long, got home and checked them and they showed no signs of wear on the ends
Put my cyclones back on the front and it seems to be ok now, test it properly on the way to work tomorrow
anyone else had this problem?
I will probably grind 1-2mm off the tappered bolts and refit at the weekend and see if the cyclones are fine
Nile Blue
Posted 1st May 2012 at 19:02
dragoon
what ET and width are they?
what size tyres are mounted?
might be the rear wheels rubbing the inside plastic sill-covers?
Team Wheelwhore
Team Limited Edition
Astor 306 Francorchamps RIP
Virtual Blue 208 GTi
quote:
I Love this place. So many illiterate deluded fool's acting 'ard . . . and so many literate intelligent people to rip them apart and knock them back down again . . . ahh Cool
Posted 1st May 2012 at 20:33
m1kee
Same size as my cyclones and tyres the same size, where the tsw's are convex and the cyclones are concave both wheels sit in exact allignment
Today with the cyclones back on the front it was fine
I am going to put it down to the bolt length i have used on the tsw's and the possibilty it is forcing the hub/disc out of shape causing brake rub
I am going to trim the bolt to the same length as the cyclone bolt
Thanks for your thoughts
Nile Blue
Posted 2nd May 2012 at 17:19
dragoon
size ain't the same as the ET
I doubt all those specs are identical...
check that
Team Wheelwhore
Posted 2nd May 2012 at 18:25
m1kee
I will definately check that cheers Dragoon
Nile Blue
Posted 2nd May 2012 at 19:15
m1kee
Sorted, took 2mm of the wheel bolts
They were peugeot wheel bolts from a car with a set of steels, as you probably know they need a bit more length on the steel wheel
Nile Blue
Posted 5th May 2012 at 11:40
Glad you got it sorted. Thumbs up
Posted 5th May 2012 at 15:04
