any ideas
thanks adam
| Author | Subject: burning oil after doing head gasket |
weemangti
Junior User Location: chippenham Registered: 02 Jul 2011 Posts: 96 Status: Offline |
my head gasket went was using loads of water and missing so done my headgasket sent the head away had it skimed and pressure tested and new valve stem oil seals put in put it all back together now after its been on idle when you pull away or rev it, it blue smokes like nakered valve stem oil seals and if you drive it hard it will miss higher up the rev range then drop a cylinder like its fouling the plug any ideas thanks adam |
fatlapit
oil seals rip it apart again and start again________________________________________ |
fatlapit
or blocked breathers________________________________________ |
stan_306gti6
Valve stem oil seals...![]() There are two types, one set for a 5mm valve stem and one set for a 6mm valve stem. I wonder if someone has put 6mm seals on 5mm stems? ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Could be worn valve guides too Did they check them? The head I had rebuilt needed 8 new exhaust valve guides,just through age/wear,not a snapper head ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
weemangti
thanks for all the input guys the head was all checked by the engineiring place and they stripped the head and checked it and fitted my stem seals all the bits were genuine peugeot it never smoked before i stripped it so i am thinking maybe dodgy stem seals |
stan_306gti6
It's either the wrong seals have been fitted, or one seal hasn't seated properly and it's letting oil into the chamber.This would make more sense as you stated that sometimes the engine goes down onto 3 cylinders, indicating that 1 cylinder has a fouled plug. Best thing to do, is to go out for a drive and as soon as you come back whip the plugs out and have a check to see what colour they are. My guess is you will find one plug is all sooted up, and it will be that cylinder that has the valve stem seal issue. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
never heard of 5mm gti6 stem seals, do make sure XU10J4R ones haven't been fitted though, as they are incorrect.masses of audi and volvo engines use the same seal as a gti6. depends how long it had gone for, but you could have a knackered bore+rings from the steam washing effect the gasket was doing . ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
weemangti
welshpug! wrote: never heard of 5mm gti6 stem seals, do make sure XU10J4R ones haven't been fitted though, as they are incorrect. masses of audi and volvo engines use the same seal as a gti6. depends how long it had gone for, but you could have a knackered bore+rings from the steam washing effect the gasket was doing . it didnt smoke before i took it apart so must be something i done sould of left the old ones and just done the gasket |
stan_306gti6
Looks like you are going to have to strip it down again and redo the seals then mate...________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
weemangti
UPDATEThe 6 had been starting a bit funny last few days then was driving it earlier come to a set of traffic lights went to stop and it cut out went to start it sounds like it has no compresion then i opened the bonnet it pumped the engine oil out the dip stick tube and out the filler cap. OH s**t !!!!!! |
fatlapit
Rings it is then________________________________________ |
weemangti
anyone no of a good engine or engine rebuilder near wiltshire |
fatlapit
Rich w mate he just built my forged turbo engine________________________________________ |
weemangti wrote: anyone no of a good engine or engine rebuilder near wiltshire miles at pugracing isn't too far from you and might be able to sort you out. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
rich_w
Seasoned Pro Location: Havant, Hampshire Registered: 29 Jul 2004 Posts: 5,412 Status: Offline |
It does sound like rings, it's also worth checking the PCV system isn't blocked.My guess is the coolant getting into the bores has washed the oil off the cylinder walls (similar to bore wash where rich running / excessive fuel washes the oil from the cylinder walls), and has worn the rings and / or bores. ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
weemangti
i spoke to a bloke called collin from pug performane in hampshire about a second hand engine seemed like a real genuine bloke just wondered anyone delt with them before |
stan_306gti6
weemangti wrote: i spoke to a bloke called collin from pug performane in hampshire about a second hand engine seemed like a real genuine bloke just wondered anyone delt with them before ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
miles is closer to you I do believe ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
swiftyboi006
stan_306gti6 wrote: weemangti wrote: i spoke to a bloke called collin from pug performane in hampshire about a second hand engine seemed like a real genuine bloke just wondered anyone delt with them before ![]() ![]() ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
fatlapit
i just bought an engine from him too a good mate of mine tho, but saying that the engine got fully rebuilt anyway lol________________________________________ |
weemangti
i picked the second hand engine up at the weekend finished fitting it today runs sweat as thumbs up to collin at pug performance in hampshire for sorting me out |
Good lad Ignore the chimps on here most have never had dealings with colin |
weemangti
bigbadbowen wrote: Good lad Ignore the chimps on here most have never had dealings with colin top bloke very helpfull would recomend him to anyone |
