Author Subject: inlet manifold part,
barnettjd77
I have been cleaning the engine bay up a bit, and when i took the manifold off there is a grey plug with two eletrical connectors inside it, when i started the car up it started to melt and smoked a bit LOL
It's on the back of the throttle body here is the pic if you can see what i'm on about...
Can you tell me what the part is ect and whether it's drivable wothout for a bit...
barnettjd77 has attached the following image:
A red rallye in progress!
Posted 25th Apr 2012 at 18:01
birk
Air temp sensor iirc
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 25th Apr 2012 at 18:14
barnettjd77
Thanks for the quick reply Smile
Ah right, mine burnt out for some reason then
the car is going from idle for a bit then changes to a bit higher revs.
this will effect the ecu or something will it?
Posted 25th Apr 2012 at 18:17
mattgti6phase2
+1
Yes it's still driveable.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
mattgti6phase2
Rough idle could be icv.
5 x a 306 owner!
Posted 25th Apr 2012 at 18:18
barnettjd77
Cheers matt and birk Thumbs up
how does it effect the car without it then?
Posted 25th Apr 2012 at 18:19
I had mine plugged into the reverse light cable/plug.
It ran ok still, I wouldn't of know any different if the rEerse lights had Been working.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 25th Apr 2012 at 18:22
mattgti6phase2
If the air temp sensor doesn't work it can't tell the Ecu how thin or dense the air coming into the engine is. In turn it won't know how much fuel to add so it won't run efficiently.
They are easy enough to replace Thumbs up
5 x a 306 owner!
Posted 25th Apr 2012 at 18:41
True but I wouldn't of know anything was a matter with mine if the reverse lights had been working.
It went well and wasnt over keen on fuel.
But I did notice every now and again it felt a bit lethargic compared to other times but that's something I've noticed with every car I've driven nearly.
Posted 25th Apr 2012 at 18:46
mattgti6phase2
I've noticed with the 6 when the inlet mani is hot due to heat soak it feels sluggish until you get going. Obviously that's due to high inlet temps in turn the engine runs lean.
5 x a 306 owner!
Posted 25th Apr 2012 at 18:58
Mine might have ran better in reverse, with the reverse switch cable plugged into it and the air temp sensor cable plugged into the gearboxLOL
Posted 25th Apr 2012 at 19:01
barnettjd77
That'll hopefully be why it has it's moments then LOL
got one on order Thumbs up
Posted 25th Apr 2012 at 19:22
