Author Subject: No sound from speakers
peetypug
Over the past month or so I've been having problems with my stereo
I'd start the car in a morning and there would be no sound, then after a while it would just come on or I would pull it out and give it a tap, then it would work
However it's now stopped working all together, the sound that is.
The sound graphic works like it's playing music but no sound at all
So today I decided I would swap the stereo for a different one and it's still the same, which ruled out the amp in the stereo
I tried 4 different ones all together and all with the same outcome
I've checked continuity to one of the speakers and it was fine, it should have been working
so now I'm baffled
Please help as my exhaust is starting to kill my hearing, I've got constant tinitus! But that could be the wife nagging at me!!
Cherry rallye - DOB Thursday 29/04/1999
Team Rallye - the leaner, meaner, better looking sister of the GTI6 Big grin
roland rat wrote:
You sir either live for the 6 or have a mental retardation to still be repairing this!
The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does its own oil change. It's just a pity the management system is so fecking temperamental.
Posted 22nd Apr 2012 at 21:58
dragoon
try measuring with a multimeter if al the wiring is ok?
Team Wheelwhore
Team Limited Edition
Astor 306 Francorchamps RIP
Virtual Blue 208 GTi
quote:
I Love this place. So many illiterate deluded fool's acting 'ard . . . and so many literate intelligent people to rip them apart and knock them back down again . . . ahh Cool
Posted 22nd Apr 2012 at 22:03
Can only be a bad connection on the speaker wiring harness ?
Posted 22nd Apr 2012 at 22:04
chris1987
Have you install new speaks or moved them around I only ask as when I put my first speakers in many years ago I put new fli one in any way thay stop working had no sd and would only work when the doors were open so we loosen the skews and dident have problem sins.
Posted 22nd Apr 2012 at 22:11
peetypug
I pinged the speaker wires and the couple I checked were fine, so at least one speaker should have worked
A for the wiring harness, Do the 2 plugs that go into the back of the stereo (doesn't need an after Market loom) have one plug further down the loom?
Could 2 wires touching cause this problem??
chris1987
I only had to undo 1 speaker I found for some reason if 1 speaker/wirer shorts you loss all your sd .
Posted 22nd Apr 2012 at 22:21
peetypug
i'll double check all the wires tomorrow night.
but i removed both door speakers and disconnected the parcel shelf to try to solve the problem
Posted 22nd Apr 2012 at 22:36
No idea about the plug but I'd say if you short one speaker it would prob affect the other ?
Check your wiring both ends ?
Posted 22nd Apr 2012 at 22:43
chris1987
Sd like a plan hope that's all it is . As I'm new here don't no everyone yet but I'm shour some off the other. G8 member. Like dragoon has idears on other things it could b if its not shorting problems hope iv helpedSmile
Posted 22nd Apr 2012 at 22:46
sixysix
Does sound like one of your speakers is shorting out which will mean that none of the speakers will make any sound.
It will most likely be one of the door speakers, probably the neg or pos wire that is catching on the bare metal of the door around where the speaker mounts Thumbs up
Take a look
Posted 22nd Apr 2012 at 22:49
Spelling No
Shour = sure
G8 = great
Idears = ideas
Iv = I've
Posted 22nd Apr 2012 at 22:53
peetypug
bigbadbowen wrote:
Spelling No
Shour = sure
G8 = great
Idears = ideas
Iv = I've
B = b
Off = of
Thumbs up
Posted 22nd Apr 2012 at 22:59
chris1987
Lol thanks on the phone soz for the spellings Whistle
Posted 22nd Apr 2012 at 23:02
peetypug
Pet hate in here is grammar, specially text speak!
So dont use it and always use fullstops at the end of sentences and you'll go far Smile
Posted 22nd Apr 2012 at 23:09
chris1987
Thanks for the heads up hope you fix you speaks Thumbs up
Posted 22nd Apr 2012 at 23:12
peetypug
sorted it, or should i say i've found the issue.
wiring to the passenger rear speaker
every time i touch the + speaker cable from the stereo loom to the plug it shuts the sound off.
gonna try some speaker cable direct to it to see what happens
Posted 23rd Apr 2012 at 19:27
smegal
I had the same problem but it was the passenger door speaker.
Ex SC-6
Now in a Megane R26
Posted 26th Apr 2012 at 23:29
