Rallye build: 11 November 1998 - a WednesdayTeam rallye,built for track
Rallye dead
Secret Team Astor...
| Author | Subject: pic's of harness mounting points |
7057sam
Seasoned Pro Location: Stowmarket,Suffolk Registered: 18 Apr 2009 Posts: 2,080 Status: Offline |
Hi guys soon to be fitting 3 point harness,just need some advice of mounts points for them thanks ________________________________________ Rallye build: 11 November 1998 - a WednesdayTeam rallye,built for track ----Click this if you like rallyes Rallye dead Secret Team Astor... |
one to the tunnel, one to the sills, rears to the harness bar on the cage and the middle one straight down to an eyelet fixed to the floor.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
chris with a pug
Seasoned Pro Location: Southampton Registered: 16 Feb 2003 Posts: 5,366 Status: Offline |
what he said.You can use the bolt hole that the bracket that holds the belt on the seal. Then mark the rest up from that. |
7057sam
So no chance of using the seat belt harness points ?________________________________________ Rallye build: 11 November 1998 - a WednesdayTeam rallye,built for track ----Click this if you like rallyes Rallye dead Secret Team Astor... |
stu
Seasoned Pro Location: Milton Keynes Registered: 22 Aug 2006 Posts: 5,525 Status: Offline |
7057sam wrote: So no chance of using the seat belt harness points ? You mean the seat belt mounting points in the rear? You can use them, but expect a crushed spine if you're ever unfortunate enough to crash....... |
7057sam
No i was thinking of the points on the floor near the base mount ________________________________________ Rallye build: 11 November 1998 - a WednesdayTeam rallye,built for track ----Click this if you like rallyes Rallye dead Secret Team Astor... |
eddy_gti6
I have used the rears seat belt mount next to the window________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
eddy_gti6
chris with a pug
![]() ![]() that is where mine are. |
7057sam wrote: No i was thinking of the points on the floor near the base mount Too low, your shoulder straps want to be as close to horizontal as you can get them. ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
Chris's one's there look pretty spot on ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
