Author Subject: gti6 abs light (how to cancel ??)
Moonstone6
hi all i was doing some work near the abs pump the other day and i disconnected the abs unit and since then the light has illuminated on the dash board to took the car to my local garage where it was plugged in in hope to reset the error but no communication can be obtained with the abs any ideas on how do remove the light on the dash ?? without removing the bulb as the system was fine en till i messed and disconnected the unit thanks guys ??????Dunno
Posted 20th Apr 2012 at 18:13
Make sure that you have reconnected it properly. Yes
The ABS faults usually go once you drive down the road and there is no fault present. If I were you I would disconnect the ABS unit, disconnect the battery for 10 mins, then reconnect the ABS unit and finally reconnect the battery.
This should hopefully clear the fault. Thumbs up
Posted 20th Apr 2012 at 19:28
Moonstone6
Thanks matey ok il give that a try il disconnect the batt n double check the connection for abs pump would you know where to find the fuse for it as I don't have the fuse label book with the car ? So I can't check them eather
Thanks for the reply matey Thumbs up
Posted 20th Apr 2012 at 19:49
daver6
The search function seems to work okay, so here's p2 http://www.306gti6.com/forum/showthread.php?id=69121
Search for p3 if need be, good luck
Wishbone Polybushes available
Posted 1st May 2012 at 08:31
Moonstone6
Search for p3 if need be, good luck[/quotes sorted it now it was just me being stupid I blew the fuse when I disconnected the abs unit lol took me a week to solve the problem Unsure
Posted 1st May 2012 at 10:21
Glad its sorted now. Thumbs up
Posted 1st May 2012 at 11:12
Moonstone6
cheers mate i was dumb i didin think to try the easy route first lol LOL
Posted 1st May 2012 at 11:52
pugsy77
This very light stayed lit on mine for about 15 minutes, whilst queuing at Heathrow T4 short stay car park spiral going upwards in a bend last Sunday. But after about an hour returning back to the car, it's disappeared apart from seeing it flashing when starting the car(which is normal?).
Will need to check the fuses over the weekend and try Stan's method if the problem persists. :thumsbup
306 RALLYE
Posted 10th Jul 2012 at 21:28
Can the Back wheel lifting cause it to come on for a while?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 11th Jul 2012 at 17:49
darzmat
good call. cause they do come up pretty easy
Posted 11th Jul 2012 at 18:06
Spiral car park= back wheel lift LOL
Posted 11th Jul 2012 at 18:09
aaron6
Back wheel on minrs been up a bit. No abs issues though.
Posted 12th Jul 2012 at 10:11
