Will the 283mm discs and callipers fit on a 306?
| Author | Subject: 406 breaks help |
peugeot96
Regular Location: verdal Registered: 14 Sep 2011 Posts: 218 Status: Offline |
Will the 283mm discs and callipers fit on a 306? |
its spelt "brakes" and no they don't fit. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
peugeot96
welshpug! wrote: its spelt "brakes" and no they don't fit. Hehehe.... sorry Why wouldnt they fit? |
peugeot96 wrote: Why wouldnt they fit? Wrong size. ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
peugeot96
owain wrote: peugeot96 wrote: Why wouldnt they fit? Wrong size. wrong size how? |
Caliper is located in a different place to on the 406 I believe, so the pad would overhang the edge of the disc. Also pretty sure the offset is wrong. Either way, you need V6 Xantia discs, and this is assuming you're talking about the 406 V6 Brembos? ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
if he;s asking about 283's they'd be the more common standard 406 brakes which wont fit.the radius of the caliper mounting lugs is larger and the offset of the discs much lower, the only 406 brake that can be made to fit with off the shelf parts is the Brembo coupe calipers. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
peugeot96
welshpug! wrote: if he;s asking about 283's they'd be the more common standard 406 brakes which wont fit. the radius of the caliper mounting lugs is larger and the offset of the discs much lower, the only 406 brake that can be made to fit with off the shelf parts is the Brembo coupe calipers. Thanks again |
if you want some calipers that will fit straight on I have some you can buy :thgumbsup________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
