RJ
| Author | Subject: wheels |
speedo306
Regular Location: Trinidad & Tobago Registered: 05 Apr 2008 Posts: 478 Status: Offline |
Hi all I converted my 1.6 automatic 306 sedan to a gti6 I currently have it running on 206gti 180 rims. I have noticed that when I lock to the right the tyre slightly rubs on the gearbox. Is this normal? If not what can be causing this problem.________________________________________ RJ |
wheels are an inch wider, plus 10mm deeper offset, so they are running about 27mm more wheel on the inside.also if you are running gti6 gearbox with standard steering rack it will do this anyway, you need to fit the gti6 pas ram. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
speedo306
