Author Subject: poor mpg
samslow
Not had the 6 long but i have noticed how pants the mpg is already ive worked out about 20mpg at the moment and im not booting it if ido boot its even worse. I am mainly town driving but even so im sure it should be slightly better. Ive been trawling through threads onhere and lamda sensor and cts comes up alot. I have had another symptom too sometimes where it hesitate occasionally like its gonna stall then comes back to normal again.
Wheres best place to get lambda sensor and cts from?
Any part no.s?
thanks
Sam
Diablo Gti6 ph 2 98
Posted 13th Apr 2012 at 12:59
CTS from Peugeot costs around £18, lambda sensor get one from any factors that sell Bosch as the genuine one is a Bosch one in a Peugeot box. Wink
Posted 13th Apr 2012 at 13:07
samslow
what do i ask for "coolant temp sensor"?
thanks for the quick reply
Diablo Gti6 ph 2 98
Posted 13th Apr 2012 at 13:08
yup, the green 2 pin one.
Posted 13th Apr 2012 at 13:09
samslow
cool!
theres loads o lambda sensors on ebay with differenct p/no s all saying 306 these worth a look and new too
Diablo Gti6 ph 2 98
Posted 13th Apr 2012 at 13:11
there will be a few differences, very early 306's had two 2 pin plugs, but all gti6's had one 4 pin plug, the length of the lead varies too, two lengths IIRC.
you can get the Bosch ones quite cheap if you don't mind a bit of soldering/crimping as you can get them minus the plug, its about £25 more for a direct fit.
Posted 13th Apr 2012 at 13:16
samslow
£24 from peugeot got in one fetching today for cts
£170 for lambda from peugeot not that ill be getting that from there
Diablo Gti6 ph 2 98
Posted 13th Apr 2012 at 13:19
£170 for the lambda, it used to be £100 and I thought that was expensive then. Shock
Posted 13th Apr 2012 at 15:04
£86 I think for a direct fit one from ECP, best to give them a call as their listings aren't showing them for a 306 LOL
Posted 13th Apr 2012 at 15:08
miles
NTK's I use (NGK brand) these are around £55.00 from a factor
www.pugracing.com
Posted 13th Apr 2012 at 15:14
MPG is not good around town I'm afraid,its a 2.0 ltr petrol at the end of the dayRoll eyes
Mine just clears 30mpg on my commute which is 40 mile round trip,does get booted a fair bitBig grin
But round town when I'm off work its not much over 20mpgNo
To put it in perspective though a bloke at works M3 shows 13mpg round town!Shock
Posted 14th Apr 2012 at 22:26
mechanical_repairs
They cost me about £60, that's what I paid last week, a Bosch unit.
Carl
Posted 14th Apr 2012 at 22:29
samslow
my best is 20mpg going from home 12 miles to town and back. my mates m5 is better or sameThumbs down
and thats tootling along light footed
Diablo Gti6 ph 2 98
Posted 18th Apr 2012 at 12:06
samslow
Carl
£60 where from? thanks
Diablo Gti6 ph 2 98
Posted 18th Apr 2012 at 12:07
http://www.carparts4less.co.uk/lambda-sensor
part number 710770395 is £47, you'll need to connect your plug, very easy.
or 710545635 £63, NGK, direct fit 1265mm long lead,
or 710545625 £62 Bosch part direct fit 5465mm lead.
Posted 18th Apr 2012 at 12:17
samslow
thanks buddy
Diablo Gti6 ph 2 98
Posted 18th Apr 2012 at 13:29
Great infoThumbs up
LOL at the length of the lead on the Bosch oneRoll eyes
Posted 18th Apr 2012 at 14:45
eddy_gti6
Get a 106 diesel like i have just got. Unreal mpg! Laugh my ass off
Posted 18th Apr 2012 at 15:21
A 5.5 metre long lambda lead? Blink
Posted 18th Apr 2012 at 16:41
lolls, 565mm
keydoarb failz
Posted 18th Apr 2012 at 16:52
ryangti6
Does your car run okay though? No other misfires, hesitation etc other than what you mention as that sounds more like the Icv needing a clean or replacing Imo.
I wouldnt automatically be blaming sensors for bad Mpg without any other symptoms suggesting that they are causing a problem. Loads of things can affect your Mpg, have you checked your spark plugs are in good condition? These can also be inspected to give you clues as to if it's running rich or lean etc.
Exhaust blowing is also another thing that will seriously affect your Mpg even if it is only a tiny leak. Also worth checking condition of airfilter etc, this could need changing or cleaning depending what you have fitted.
Unless one of those sensors are actually f**ked then your money could be much better spent on a good full service.
Ryan
Posted 18th Apr 2012 at 17:06
heliosphan
Have you checked to see if you're towing a large trailer everywhere?
Have you removed the galleon sail from the roof yet? Some P2's came with these from the factory.
Posted 18th Apr 2012 at 17:45
samslow
Ive now changed the CTS and havent done enough miles to see if its made a difference. I havent seen the hesitance/like its gonna stall issue though since but it was intermittent.
I have a long long list of things to do on the car and plugs and service items are there but ill have a check now anyway. Ive spent a fair bit already on it. But i cant do it all at once as wallet cant take it!!Thumbs down Generally otherwise it runs great. just abit juicyRoll eyes . i do think its running a bit rich pipes a bit sooty iirc
Diablo Gti6 ph 2 98
Posted 20th Apr 2012 at 16:29
