Author Subject: **urgent** (but stupid lol)
darzmat
i know this is stupid,
but i just did an oil change and i was distracted by a mate and i forgot to change my oil filter.
after the oil has settled can i change the filter without it pouring oil all over me?
im pretty sure once its settled i should be able to.
cheers guys
mucho apprectiated
Posted 10th Apr 2012 at 14:19
just catch any oil you waste and tip it back in
Posted 10th Apr 2012 at 14:25
anth
yeah i would have thought so mate, ive never tried it myself though Smile
Posted 10th Apr 2012 at 14:26
Yes, it will be fine. The main oil is below the filter anyway sat in the sump.
You will lose a very small amount, just check the level afterwards as when you start the engine with the new filter on, it will fill up and drop the sump level slightly. Yes
Posted 10th Apr 2012 at 14:40
darzmat
ok cheers guys.
another question.
ive been reading the faq on changing the gearbox oil, and the plug welly is undoing to drain the oil is in a different position to mine.
any ideas?
there is also a round plastic plug on the bottom of the gear box what is this for??
cheers guys
Darius
Posted 10th Apr 2012 at 15:06
darzmat wrote:
ok cheers guys.
another question.
any ideas?
cheers guys
Darius
The round plastic plug is the bottom bush for the clutch release arm, don't touch it.
Posted 10th Apr 2012 at 15:09
darzmat
daveyboy wrote:
darzmat wrote:
ok cheers guys.
another question.
any ideas?
cheers guys
Darius
OOPS.... it didnt go anywhere, it mov ed a little but car is still engaging into gear so al is good i think.
Posted 10th Apr 2012 at 15:27
The gearbox drain plug is at the rear of the diff housing. Yes
You can undo this by using an 8mm square tool or a 21mm socket (which I prefer).
Posted 10th Apr 2012 at 15:29
darzmat
i cant for the life of me get a 21mm socket on it as the subframe is in the way.
i would use an adjustable spanner but my van is in the garage so lacking a few tools at home :@
Posted 10th Apr 2012 at 16:26
At least you didn't forget to put oil back in before starting, Ive seen that done before.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 10th Apr 2012 at 17:33
davedgti6
How about putting the new oil in without putting the drain plug back in Doh , or putting new gearbox oil in with no driveshafts in, LOL Doh , I may have done one or both of those things Hmm
Posted 10th Apr 2012 at 19:24
darzmat
lol someone mentioned doing that in a post i found when reading up about changing the gear box oil.
it was the royal purple stuff, he put it in then went for lunch came back and realised he hadnt put the driveshafts in.
well i eventually got it done anyways, put 2 litres in but nothing came out the hole on the side of the box, so when im next in town i will grab some more. was only about a litre that came out when i drained it lol. and gear change feels a hell of alot less notchy and isnt grinding into reverse now. so im delighted
Posted 10th Apr 2012 at 19:56
swiftyboi006
2 litres is all a gearbox will take. Well 2.1 to be exact. Sounds like you have 3 litres in yours
Black p3 Love
Posted 11th Apr 2012 at 09:04
Really? Unsure
I've never had a problem getting a 21mm socket and ratchet on it. It is close to the subframe but it doesn't foul access...No
Anyway, well done for getting it done. Thumbs up
Posted 11th Apr 2012 at 09:38
