Author Subject: Another Fuel Gauge Problem
gtylerroberts@manx.net
Hi All,
My Rallye has just started having a problem with the fuel gauge. On Ignition the gauge goes up to full, then after a few moments drops to just above empty.
I have a full tank of fuel - check!
I have also removed the sender unit and checked the resistance at the plug. It reads from around 50 - 350 ohms which I believe to be ok. Also noticed at the same time that the rear drivers side side light has also stopped working.
Any ideas would be gratefully received.
Thanks
Posted 8th Apr 2012 at 20:17
Ok - I have ran a live from the passenger side light to the drivers side. But now I have fuel gauge working as well. Can't make sense of it. All fuses are fine. It will do for now but would still like to fix properly.
Posted 8th Apr 2012 at 21:04
mrdeey
The arm on the things is always moving ,its all part of the fuel pump assembly , it changes the resistance as it moves and so wears out a bit , get yourself another pump assembly off here , easy to change , £20 odd
now new booted , boosted and flying again!
