Author Subject: Xasra vts Box
b11 bob Banned!
Is fitting a Vts box a straightforward job currently got a gti6 box in my gti6 engined 205 is the clutch ,driveshafts ,selector fork and clutch cable the same ?Are there any mods i may need to make ?Dont want to take my gti6 box out to find that the vts box requires additional parts.
205 GTI6 235 bhp at 7400 rpm
Posted 6th Apr 2012 at 00:41
yup, straight on.
Posted 6th Apr 2012 at 09:11
Lift reverse cable if there is one may or may not be needed - can't remember at the moment which is which!
Posted 6th Apr 2012 at 09:15
ohh yeah, if that's present, don't use it or you wont have many gears LOL
Posted 6th Apr 2012 at 09:23
Yeah took me ages to find 1/2/5/R in my BE3 after changing from a BE1 in my 205. In the days before forums Wink
Posted 6th Apr 2012 at 09:37
b11 bob Banned!
When converted from non lift reverse cable to reverse lift like on a gti 6 box i had to fit my 205 1.6 gti gear stick which had lift up for gti 6 reverse.Do i need to change this or can i still use it without using the lift up function ?
Posted 6th Apr 2012 at 11:07
miles
Depends on how the conversion was done, if done properly you need to swap
1. Clutch Arm and shaft
2. Diff
3. Top Selector Arm
If not then you never know what's been done
www.pugracing.com
Posted 6th Apr 2012 at 11:20
1.6 and 1.9 gearsticks are the same, as are BE1 and BE3, they just dont have the cable stuff attached.
Posted 6th Apr 2012 at 11:21
b11 bob Banned!
Ok so it looks like a straight swap gearbox wise i did change the i think it was the inner driveshaft due to the diff seals being different on a gti6 box would this driveshaft be ok for the vts box or would i have to change it back to 1.9 gti spec ?
Posted 6th Apr 2012 at 11:46
all BE diff seals are the same, the gti6 diff is the same as a vts diff so keep your shaft as it is.
Posted 6th Apr 2012 at 12:10
b11 bob Banned!
Cheers pal
Posted 6th Apr 2012 at 12:26
tvrfan007
As per Welshpug my Rallye has a VTS box on, straight swap. Seals the same and diffs interchangeable, I put an LSD in mine.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 6th Apr 2012 at 14:08
I had a VTS box in my 309 running a VTS engine,only thing I would say I did not like as much as the 6 speed are the gear ratios of the 5 speedThumbs down
Posted 12th Apr 2012 at 20:52
b11 bob Banned!
Any gears in particular? I dont like the gears on the 6 speed 3rd and 4th are to short.
Posted 13th Apr 2012 at 04:14
you should like the vts box then!!
as its the closeness of the 6 speed I like
Posted 13th Apr 2012 at 11:10
yippeekayay
Got two boxes for sale bob if you havent got one one 70k and one 36k...both ready for collection or drop to you?
x box "yippeekayaymofo"
Posted 13th Apr 2012 at 11:19
b11 bob Banned!
I already have one but thanks for the offer next time you in Brum and you got some spare time let me know as you seem to come across so many bits for peugeots.You would be the ideal person to advise me on what i may need to inprove my car.
Posted 13th Apr 2012 at 11:41
samslow
out of interest why do people put xsara boxes in pugs? are they 6 spd too?
Diablo Gti6 ph 2 98
Posted 13th Apr 2012 at 16:56
no, they're 5 speed, a bit stronger, also fit better in a 205 than a 6 speed box.
Posted 13th Apr 2012 at 17:29
tvrfan007
I changed as i preferred the 5 speed to the 6 speed, for track work ideally but it's also still a weekend toy.
Not that i've driven it since. :'(
I'm Si btw Tee hee
Posted 15th Apr 2012 at 10:43
