Author Subject: window going up
darzmat
ive had a seach but not found the same problem,
i took my door card off yesterday to repair it, window worked fine previously.
put the door card back on. plugged in the window switch.,
went for a drive and put my window down as i was smoking. about 30seconds later the window goes up.
then the switch doesnt do anything for a while, then it will eventually go up.
any ideas as to what is causing it??
bloody annoying when your smoking and the window goes up while your flicking the ash Angry
Posted 5th Apr 2012 at 00:22
anth
LOL
Sounds like the loom is shorting or maybe even the switch check there are no breaks in the wire.
Posted 5th Apr 2012 at 09:27
borked wires in the door-body loom are quite likely, also a sticky switch.
Posted 5th Apr 2012 at 12:36
darzmat
to save starting another thread.
does anyone know the part number for the rubber gromet that goes through the front windows with the brass clip.
the rubber grommet is falling apart and is causing my passenger window to fall down lol.
figured it out today, its the gromet that pushes through the window and onto the green bit on the runner
hope that makes sense
cheers Darius
Posted 7th Apr 2012 at 23:29
warner
Think you can only get it with the green bit?
'96 GTI-6 daily
'93 180SX drifter
20 Febuary 1997 - Thursday's car..has far to go? Wink
Posted 8th Apr 2012 at 01:23
sixysix
You can buy the gromit from Peugeot as I got one from them last year.
I can't remember the part number but will try and find it for you Smile
I also have a brand new green clip for the passenger side if you need one as pretty sure these are not seperate and only come with a complete window regulator Thumbs up
Take a look
Posted 8th Apr 2012 at 01:59
