Author Subject: engine hesitation whilst driving and bogging down
sixysix
Hi guys, been having a little problem with the car for the last week. Car seems to hesitate on occassion whilst accelarating. For a second then is normal for a bit, then will do it again and it seems to be getting worse Sad car has also stalled a couple of times as well. I have a new map sensor to gfit and fuel filer but just wondering if someone else has had similar problems or can point me in the right direction? Car is no mis firing and drives fine other than the hesitation and it idles fine?? Sorry for the text, I'm on phone and can't space it properly LOL cheers for any help guys Smile
Take a look
Posted 3rd Apr 2012 at 12:57
Lambda sensor. Wink
Posted 3rd Apr 2012 at 13:00
davewagon
How much do these cost? and how would a clueless person go about buying one (new)?
Team: Moonstone GTI-6™
Team: Working air-con™
ian7675 wrote:
Posted 3rd Apr 2012 at 13:03
sixysix
stan_306gti6 wrote:
Lambda sensor. Wink
cheers Stan Smile is pug best place for lambder or is ECP, GSF good on the lambders? Smile
Take a look
Posted 3rd Apr 2012 at 14:01
The genuine one is made by Bosch, boxed up in a Pug box and will cost you near to £140 these days. You are better off to go a factors and ask for a Bosch one and you will get an identical piece of kit but without the over-inflated price from Pug. Yes
Posted 3rd Apr 2012 at 14:18
pebbles167
I agree with what has been said, however try fitting the map sensor first. I had exactly the same symptoms as you and it turned out to be that.
2005 Peugeot 206 GTI 180
2008 BMW K1200R
Posted 3rd Apr 2012 at 14:47
sixysix
Cheers guys Thumbs up
I have just got home now and just fitted the new map sensor and done a reset so will give that a whirl and see how she drives on the way to work tomorrow Smile
Would go out tonight but it's cold, dark and wet and petrol is another factor to consider LOL
If no change, then I will grap the Lambda sensor from ECP which is just round the corner from work and try that tomorrow Smile
- Mark Smile
Take a look
Posted 3rd Apr 2012 at 21:13
Why is a Bosch wideband lambda much cheaper than the standard narrow band one?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 4th Apr 2012 at 05:08
I'm not sure Andy, I've never checked the price of a wide band one, even though I have one. LOL
Posted 4th Apr 2012 at 07:43
I would have said throttle position sensor over lambda tbh Wink
Especially as he's not mentioned a huge increase in fuel bills.
Andy - maybe more cars use them now! There aren't exactly many different types of lambda, just different plugs!
Posted 4th Apr 2012 at 09:53
Easy way to find out.
Disconnect the lambda and go for a drive. If the issue is loads better you need a new lambda. Don't just leave it unplugged though and think the problem is solved as this will use more fuel and will ruin a CAT if you have one and run like this long-term...Yes
Posted 4th Apr 2012 at 09:57
It could also be the wiring to the throttle position sensor too - check the pins are in the plug properly.
Posted 4th Apr 2012 at 10:50
sixysix
I was also thinking tps in the first place after the map but could any I guess. Anyway, drive the 20 miles to work today and not a hiccup, all smooth after fitting the map sensor so all good atm Smile will see how she blows Smile cheers guys :thumsup
Take a look
Posted 4th Apr 2012 at 12:28
Sounds good so far Mark, hopefully its cured. Hmm
Posted 4th Apr 2012 at 13:40
clen666
Stan, do you use only the wideband lambda or do you have both wide and narrow fitted?
Team 'unintentional rat look'
Posted 4th Apr 2012 at 20:28
Only the wideband one mate. Wink
Posted 4th Apr 2012 at 20:31
sixysix
Yes it would seem so, drive home and still fine so looks to be ok now Smile
I have already ordered the lambda from ECP which is sitting on thier shelf ready for me to collect!
I might not need it now but might just get it anyway as it's not too bad for a P1 Lambda @ £58
Spares are always good LOL
Take a look
Posted 4th Apr 2012 at 23:47
