Author Subject: MAP Sensor?
bengti6
Having a few issues with gti6 at the mo, jump in and start it one day its fine, another day it wont idle and wants to cut out and another day it hunts from 900rpm to 2500rpm ?? Any ideas i was thinking MAP Sensor maybe but wanted to check if any one could help before i start splashing out. cheers
205 gti6 1989
Posted 30th Mar 2012 at 18:19
Icv or map. Sounds like both tbh
Posted 30th Mar 2012 at 18:41
ryangti6
Sounds like Icv to me.
Give it a clean first and reset the ecu and see how that goes, if it cures the problem but comes back fairly soon then get a replacement.
Ryan
Posted 30th Mar 2012 at 20:12
^^This. Yes
Posted 31st Mar 2012 at 09:28
Also don't do what I did and get a pattern one. A Peugeot one magnetti marrelli is so worth the extra I promise.
Posted 31st Mar 2012 at 10:25
webster
Replaced my ICV, which solved stalling, but when cold/wet the car seems really hesistant - almost like it's choking?
Always fine when warm, and problem seems intermittent.
Map sensor??
cress87 wrote:
I'm stopped for speeding on a daily basis but now the police are aware that I live for the 306 they dare not interfere, just sit in their cars quaking as I drive past.
Posted 17th Apr 2012 at 14:03
Map sensor??
I would suggest lambda in your situation unless this has been replaced recently? Unsure
Posted 17th Apr 2012 at 15:55
Or, it could be the CTS. Only around £18 from Pug and easy to change. It could have failed making the car run lean when in fact the engine is cold and requires a richer mixture...
Posted 17th Apr 2012 at 15:57
anth
Cts and lambda have been changed with about 5k or so.
What about tps?
Posted 17th Apr 2012 at 16:54
webster
It's really weird as it's intermittent. Seems to be getting worse though, if I put the car in 5th gear at 30mph when cold, then give it any kind of accel it stutters heavily.
Posted 18th Apr 2012 at 12:15
dont put it in 5th at 30 Thumbs up
Posted 18th Apr 2012 at 12:18
Could be the air intake temp sensor. Does this problem only exist from cold?
Posted 18th Apr 2012 at 16:44
davidmartin
Is it like this ? http://www.306gti6.com/forum/showthread.php?id=139549
just looked at the clicky in that link,they used to be 40 quid with them
pet hate, the cat
Posted 19th Apr 2012 at 00:19
webster
Appears that way, once warmed up drives fine.
Everytime I've gone to show anth it never did it, however he experienced it last night, and it was from cold and slightly wet.
Posted 19th Apr 2012 at 10:35
webster
This only highlights the problem, doing it at 40/50 has the same effect.
Posted 19th Apr 2012 at 12:48
