Author Subject: Map Sensor
notoriouslor
Anyone got a phase 1/2 map sensor in or near Edinburgh as my car is having major stuttering problems and I'm supposed to be driving to Pitlochry tomorrow, doesn't look like it now though Thumbs down
Posted 29th Mar 2012 at 18:37
Stuttering at what sort of rpm?
Posted 29th Mar 2012 at 22:57
notoriouslor
The revs aren't really going up and down as such but it does it right through the range, the car sounds like a diesel and has no power whatsoever, just reading through the other stutter posts I'm guessing that its either the icv or the map sensor, changed the icv today and its still the same so I'm going to try the map next
Posted 29th Mar 2012 at 23:41
notoriouslor
Hopefully get it sorted as well otherwise I'm in my mums toyota auris, bad times Thumbs down
Posted 29th Mar 2012 at 23:43
Coil pack 100 %
It's probably that your car is running on 3 cylinders. If you pull the clips that connect the injectors one by one replacing them each time I bet removing a particular one will cause no change to the running of the engine. Because you will be stopping fuel from going in the cylinder where in isn't much point, as without a cool there's no spark/ ignition.
Which ever one which makes no difference to the car running will correspond to the coil on the same cylinder
Posted 30th Mar 2012 at 00:42
Have to agree, does sound like a coil pack. Yes
They are around £75 each from Pug so make sure it is this before you go buying. Yes
Posted 30th Mar 2012 at 07:23
mattgti6phase2
If it is a coil you should smell fuel very strongly tbh also if you have a cat the unburnt fuel will ruin it. If you suspect the map sensor then un plug it and if it makes no difference to it running rough then it's that.
Both are p**s easy to diagnose/fix
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 30th Mar 2012 at 09:56
If its well down on power though i doubt its the map
Posted 30th Mar 2012 at 10:40
Sounding like a diesel you say? Deffo sounds like its running on 3. Yes
Posted 30th Mar 2012 at 11:09
mattgti6phase2
IF LOL didnt say it was although the car is still down on power if the MAP sensor is f**ked. Unplug your own and drive the car Big grin
5 x a 306 owner!
Posted 30th Mar 2012 at 11:37
swiftyboi006
Running on 3 cylinders sounds like a diesel, mine kept doing it as i lost an injector clip so it kept jumping and running on 3 cylinders. It is most def this Thumbs up
Black p3 Love
Posted 30th Mar 2012 at 14:07
If you ever doubt the MAP sensor, the easy way to test it to get the car running at idle then unplug the MAP. It should stall. If it doesn't then it is faulty.
However in this particular case I vote coil pack. Smile
Posted 30th Mar 2012 at 14:11
mattgti6phase2
I also vote coil pack was just chucking the map issue out there. As stan said it'll run like a dog then stall.
I have had to replace 2 coil packs in 6 months Roll eyes lucky I have a friend who has a mass supply. Bloody thing sounded likes scooby on 3 cylinders LOL as said above though if you have a cat it'll ruin it for sure.
5 x a 306 owner!
Posted 30th Mar 2012 at 15:51
Tbh wen my coil went I thought it sounded like a mini mustang Lmao.
Posted 30th Mar 2012 at 18:43
notoriouslor
To be honest it does sound alright, bit like a boxer lol, the thing that made me think it was the map was I took it of and cleaned it, the car then worked fine for about 60-70 miles. Then it done it again, so I cleaned it again and low and behold it worked again, now no amount of cleaning is doing anything now, I'm in pitlochry till sunday now so nothing much will be happening till the start of the week
Posted 30th Mar 2012 at 22:55
notoriouslor
Okay, got the coilpacks today, went to fit them and some joker has obviously had them out before but has almost rounded out the bolts holding them in. I've got half of them out but can't get the others out and it's started p**sing down with hail again so I just gave up. Any suggestions to get the bolts out?
Posted 4th Apr 2012 at 17:44
Next size up Torx bit and hammer Thumbs up
Posted 4th Apr 2012 at 17:55
notoriouslor
I'll give that a try once the weather gets a bit better, should I reset the ecu after changing the coilpacks?
Posted 4th Apr 2012 at 18:19
No need. Thumbs up
Posted 4th Apr 2012 at 18:37
swiftyboi006
Let us know how it is when changed Thumbs up
Black p3 Love
Posted 4th Apr 2012 at 19:26
notoriouslor
And the problem is still the same, i swear I'm goint to set fire to this piece of crap Dunno
Posted 4th Apr 2012 at 20:06
You've fitted 4 new coils and the problem still persists?
Did you remove the plugs and see if there was one that was badly fouled? Unsure
Posted 4th Apr 2012 at 20:12
notoriouslor
They all looked fine to be honest
Posted 4th Apr 2012 at 20:20
Ok, next thing to try is to get the car running and disconnect one coil at a time to see if it makes a difference to the running of the engine. Each time you disconnect one it should make a noticeable difference. If you unplug one and there is no difference at all, that will be the cylinder with the problem.
Even though the plugs looked good it doesn't mean that one isn't faulty. Were the coil packs new or used?
Posted 4th Apr 2012 at 20:25
Really you should have done that test prior to getting any coils Sad
As Stan says pull the cables out for the injectors so you know where you can focus your attention.
Posted 4th Apr 2012 at 20:38
