Author Subject: P/S window not working
pooouk
I have looked at the door loom and all looks ok. I have now checked the plug on the door switch and I am getting 12v there, so confirming that the wiring is good.
Any ideas as to whether it will be the motor or the switch? It didn't make any funny noises or anything, it just got a bit intermitent and then stopped working altogether (luckily in the up position!!)
Cheers,
Nick
AKA nick on 205gtidrivers.com
Posted 29th Mar 2012 at 18:19
Just be the switch it's self just pop out and replace,.. For about £10
Posted 30th Mar 2012 at 01:25
pooouk
But, thinking about it, it doesn't work with the switch on the drivers side either.... I reckon I might have just answered my own question!!
Nick
Posted 30th Mar 2012 at 08:10
do you have both switches fitted?.....
Posted 30th Mar 2012 at 11:10
checked fuses?
theres a diagram in the faq section as to what fuse works what try just checking there 1st! Smile
Posted 30th Mar 2012 at 17:40
pooouk
Both switches fitted, drivers window works fine. Fuses not checked. but I'll have a look in the morning.
Cheers,
Nick
Posted 30th Mar 2012 at 23:02
If you've got 12v at the switch it won't be a fuse.
Whip the door card off and see if you've got 12v at the motor when you press the switch. If so, the motor/regulator will need replacing. Yes
Posted 31st Mar 2012 at 09:31
