Author Subject: gearbox
mike rallye
hi guys am after some advice on what to do,i have noticed i got a slight gearbox leaks .it is not coming from the end plate ,it is coming from the next bit of the box(sorry dont know what it called). what would you guys suggest i do,by a recondition one which has new parts/gears fitted ?
the current gearbox has done 174,000 miles to
any advice/help would be gratefull.
Posted 27th Mar 2012 at 20:08
judge dead
any pictures m8? is it from near driveshafts i took mines out for a clutch put them back in and cut a driveshaft seal on g.box. Cost like 11.20 to get new pug one.
Posted 27th Mar 2012 at 20:11
As above probably driveshaft sealsThumbs up
When your doing your balljoint change the seals too!!Big grin
As you need to split the suspension to remove driveshaft from gearboxYes
Posted 27th Mar 2012 at 20:27
mike rallye
no it not coming from the driveshaft seal,the driveshaft seal on the passenger side is dry. i tryed to get a pics but it did coming out correctly. i will try and explain.
say if you were taking the backing plate off,then you removed the gears. then you undo start to remove the next part of the box,it has about 13 bolts holding it on.it is leaking from there from what i can see.
Posted 27th Mar 2012 at 20:39
mattgti6phase2
Where the box is bolted on to the engine?? Dunno
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 27th Mar 2012 at 22:13
I think he means the main part of the gearbox Matt.
Where you have the end section, then the main body and this main body is then in turn bolted to the bellhousing.
If it is that, I am unsure if there is a gasket fitted to that mating face or not? I would guess Pug used sealant on it and now it's leaking. Sad
Posted 27th Mar 2012 at 22:17
mattgti6phase2
I'm confused Crazy
So here's 2 random options.
1. The oil level plug may be loose.
2. It could be the crank main oil seal. These are known to leak.
I'd suggest given the oil a sniff if it's engine oil then it's probably the oil seal.
5 x a 306 owner!
Posted 28th Mar 2012 at 00:47
As above, Ive had this a while now and am keeping an eye on it, the amount coming out is negliable atm but im planning to buy a flywheel soonish and have it fitted while the seals replaced Razz I like to turn bads into goods where ever i can.
It gets me into financial trouble as you can imagine.
Posted 28th Mar 2012 at 01:05
The flywheel end crank seal is actually pretty reliable, and very rarely fails. Yes
It is usually the two sealing strips which fit down down the sides of number 1 main bearing cap which often fail, and the leak then gets mis-diagnosed as the crank seal...
Gearbox off job either way though.
Posted 28th Mar 2012 at 07:29
davedgti6
Mine was leaking from here, (selector seal?) worth a look? Dunno
Posted 28th Mar 2012 at 19:23
mike rallye
thats for that pic and info guys, i will have a look over the weekend
Posted 28th Mar 2012 at 19:45
matt evans
If its leaking out the bottom of the box, ie an ooze from where the bellhousing meets the block, id say rear main oil seal. Last 2 bottom ends ive worked on had both got leaking rear main oil seals. Not bad, but enough to drip every few days.
honestly3k wrote:
owain wrote:
Posted 30th Mar 2012 at 10:23
Best get one ordered for when my box is out I thinkYes
Do get a damp patch down there............LOL
Something to with old age I think!!!Whistle
Posted 30th Mar 2012 at 17:36
Any progress on finding the source of the leak yet? Unsure
Posted 6th Apr 2012 at 07:37
