Author Subject: Mot fail
306er
Well found out today that my drivers side back wheel wasent holding while handbrake was
up, so while i had the wheels off i change disc and pads. Also got the wd40 on the arms of the calipers, tweeked the handbrake and still
the wheel keeps turning while handbrakes on.
Does any one know how far the piston in the caliper should move while moving the arm?
diablo 6 black 6 China Blue GTI 6
Posted 24th Mar 2012 at 19:04
It may be that the arm isn't moving as far as it should - it should move all the way round past the 90 degree mark. Also handbrake cable might be knackered.
Posted 25th Mar 2012 at 11:59
306er
Cant get get over how im still doing this job.
Iv let the handrake off and the arm is moving got pads and disc off to see how much
The piston is moving its about 1mm if that, iv sparyed everything on the the piston, wound the f**ker in and its still only moving a mm
surly its more thats needed?
Posted 25th Mar 2012 at 14:05
Don't know about the pad, but does the arm move round past the 90 degree point?
Posted 25th Mar 2012 at 14:20
webster
Isn't there some kind of rear bias valve that needs checking before your mot? i forget, someone will clarify.
cress87 wrote:
I'm stopped for speeding on a daily basis but now the police are aware that I live for the 306 they dare not interfere, just sit in their cars quaking as I drive past.
Posted 25th Mar 2012 at 15:31
306er
yeah it move fine just like the other side but im now if found that the cables under the console drivers side cable is up more than the passenger side, but the piston arms are in the same postions as each other?
Posted 25th Mar 2012 at 15:32
So the arms on both sides will both go back past the 90 degree point without issue? In which case you've probably got a seized handbrake cable.
Posted 25th Mar 2012 at 15:35
306er
Is there any point of the cable to spary wd40 that might help
Posted 25th Mar 2012 at 15:45
Nope, it's too long to make a difference. They're only about a tenner from GSF, just replace them both.
Posted 25th Mar 2012 at 15:46
Use a bar on the handbrake arm on the caliper and see if the wheel turns thenThumbs up
If the wheel won't turn you need a new handbrake cableYes
If the wheel still turns with the handbrake arm fully pushed forward/on the caliper is fookedThumbs down
Posted 25th Mar 2012 at 20:44
Judging by that picture, I'm voting handbrake cable. Yes
Posted 25th Mar 2012 at 21:57
looks like the cable has stretched by that photo Unsure mine is like that now and it's pretty poor. will change it at some point before its next MOT. i put the handbrake on when parked on a steep hill and put it in gear aswell just to be safe. when i got back in it and took it out of gear it started rolling down the hill .. handbrake still on LOL
Posted 26th Mar 2012 at 10:36
That could only happen to you...LOL
Posted 26th Mar 2012 at 14:57
I left my old one in gear outside a shop on a hill and came out and it was at the bottom about 3 inch of some bollards, strange I was sure I parked further up I thought.
Anyway next time I parked in the same place, I came out of the shop and it was halfway to the bollards from where it was parked, moving forward slowly then stopping then moving, one notch at a time of the gears LOL
Just a warning that If it's steep enough you can't rely on the earbud to save it either
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 28th Mar 2012 at 19:32
To be fair earbud's aren't much use for protecting cars!!!LOL
Posted 29th Mar 2012 at 20:45
davedgti6
Them earbuds are no use, leave it in gear and point wheel into kerb works for me Thumbs up
Posted 29th Mar 2012 at 21:17
tvrfan007
Someone who was actually taught to drive it seems!
That's pretty basic motoring, pointing your wheels at the kerb on a steep hill. Yes
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 31st Mar 2012 at 08:13
LOL ment gearbox, you can't rely on the gearbox of its steep, and if there's no kerbs, like a car park surrounded by walls with a shop at the bottom protected by concrete bollards like I was, you really need a brick or a good few packs of earbuds to chock the wheel.
Posted 31st Mar 2012 at 11:24
LOL
Thing is I can ACTUALLY imagine you trying that...Yes LOL
Posted 31st Mar 2012 at 14:31
