Author Subject: Wipers canceling all over the screen!
ben306
Wipers cancel anywhere in the screen as soon as you turn your wipers off, not completing the cycle and canceling at the bottom of the screen. (in the hdi by the way, not the rallye)
Tried swapping the motor, no joy. Anyone any ideas?
My 306 Rallye Project Thread
Lap of Anglesey Coastal
3 sisters circuit
Few laps at Blyton
Posted 19th Mar 2012 at 15:05
try the stalk + relay
Posted 19th Mar 2012 at 15:07
I am voting for the relay. Yes
Posted 19th Mar 2012 at 22:55
marc l
Hi guys I've got the exact problem and it's quite annoying!
So the general idea is the relays at fault? What one is it in the fuse box? Smile
2001 BLACK Phase 3 XS - Sold April 2010
1999 WHITE Phase 3 GTi6 Big grin
1991 Peugeot 205 1.6 GTi - Track Car
Posted 12th Jun 2012 at 13:54
smegal
Have you unplugged the rain sensor?
Ex SC-6
Now in a Megane R26
Posted 12th Jun 2012 at 13:58
I have, and now only one wiper setting works. Any way to correct this? (bar the obvious answer of plugging it back in, aha)
Posted 12th Jun 2012 at 14:03
The front wiper relays are the two purple ones next to each other in the fusebox. Yes
If these don't solve the problem, it's either the rain sensor as Smegal says or the stalk itself. It won't be the motor. No
Posted 12th Jun 2012 at 14:05
yeah same problem here,..
i just wondered if it had something to do with the blue relay in the rear wiper getting wet and screwing around with things,..
i'll try the two purple relays though Wink
Posted 12th Jun 2012 at 14:08
smegal
I'd say that's the source of your problem. Not sure if there is a way to bypass it. I'd have a look at a wiring diagram and see if it reveals what the wires to the sensor do.
Ex SC-6
Now in a Megane R26
Posted 12th Jun 2012 at 14:19
marc l
Mine does it when you are not using the auto wipers (when you push the stalk down for 1 wipe)
So I'm thinking replace both relays. Could anyone help me please and tell me the Peugeot part numbers? Smile
Posted 12th Jun 2012 at 18:08
Mines started doing this also.
How much are the 2 relays?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 12th Jun 2012 at 18:42
mr swampy s16
**BAD SELLER**
Had this in the 406 v6 coupe, changed the motor and the relays all to no avail!!!
Turned out it was the rain sensor
Posted 12th Jun 2012 at 19:12
Mine doesn't cancel in the middle of screen with the rain sensor positiOn 1 setting on, it only does it when. Press down for a single
Wipe
Posted 12th Jun 2012 at 19:32
I have a spare purple relay so chopped and changed
When set for rain sensors it's stops all over the place but eventually returns back to start position an same when pressed down for single wipe,..
Rain sensor or stork then? How do you unplug the rain sensor?
Never had to mess with that before! Dunno
Edit:
Worked out how to remove the rain sensor
Still behaving the same! Dry
Posted 13th Jun 2012 at 14:31
Mines fixed! Big grin
After pugjim diagnosed the problem as a Wiper motor on it's way out I got a replacement 15 minute job
and back to normality Thumbs up
Posted 21st Jun 2012 at 02:39
marc l
I need to look at mine, u didn't fancy cleaning the terminals up before replacing the motor?
Posted 21st Jun 2012 at 08:46
terminals looked fine,..
I'll be pulling my other apart when I get time though to see why it was doing it? Dunno
but for the £20 it costs for one I knew worked I couldn't be arsed LOL
Posted 21st Jun 2012 at 11:40
Had his a few times and it's been the motor at fault as that's where he park switch is located I think iirc?
However tonight I took mine out to run a boost gauge pipe through he bulkhead and since putting the wiper moor and linkage back on its messing about. On rain sensor it either stays on at slow wipe speed or does one wipe every 30 seconds but stops in the wrong place. One flick down and it just stops soon as you let go of the stalk.
Think I should check the plug I immagine. Only thing I've done is unplug the thing and plug it back in :/.
Posted 9th Jul 2012 at 00:13
yeah it could just be the plug terminal I just changed mine for another one! and now works fine again i've put my old one to one side,.. should I get chance to have a mess about I'll work out exactly why it went!
Posted 9th Jul 2012 at 01:38
Cjwatson27
Bit of a revival my wipers just stop where has soon has you let go of the stalk? Would my car have a rain sensor it’s a R reg ph2 ? Only reason I ask is it was a stripped out track car and I’ve put the interior back in. Also should it have alarm sensors in the A pillars, my trim does but couldn’t find any plugs on the car ?
Thanks Chris
Posted 3rd Mar 2019 at 20:38
I just changed my wiper motor and it cured it,..
Any 306 wipers should work,..
But if your looking for an exact diagnosis then could be just the brushes the the wiper motor it's self
Posted 3rd Mar 2019 at 20:43
Cjwatson27
Cheers I’ll get a wiper motor ordered up.
Posted 3rd Mar 2019 at 21:00
blandy
Just done exactly the same thing and swapped wiper motor with another as kept sitting up to high.
Posted 4th Mar 2019 at 13:33
miki4
Often if the wiper stutters or stops at some point where it's not meant to, it's the circular PCB in the unit of the wiper motor, not the motor itself. If you take it apart, you will see it right away. It looks like a big potentiometer with circular circuit tracks and a slider. These need to be cleaned with some (isopropyl) alcohol and the slider, if neccessary, slightly sanded. Bend the slider just a little bit to apply more force to the track and regrease it. I repaired mine that way.
When reassembling take care of the arrows on the housing to line everything up. Thumbs up
Posted 4th Mar 2019 at 18:21
