displaying posts 26 to 37 of 37
Pages (2): 1 [2]
Author Subject: Timing Belt
aaron6
Ah... Still, a competant mechanic should be able to do adjustable pulleys easy enough surely?
Posted 22nd Mar 2012 at 13:22
darzmat
you still selling your 6 cammy?? seen it on gumtree the other day
Posted 22nd Mar 2012 at 13:33
A competent mechanic should be able to do adjustable cam pulleys Aaron, yes. Yes
Your right about the bottom pulley issue though, if you're not aware of this issue and you try and do a belt that has this problem it could easily go wrong. Sad
I keep a standard bottom pulley in perfect condition in my toolbox for whenever I do a belt just for timing purposes, although to be honest you don't need the bottom pulley to line it up if you know where the woodruff key should be at half stroke...
Posted 22nd Mar 2012 at 13:53
aaron6
Tipex!
Posted 22nd Mar 2012 at 14:37
aaron6 wrote:
Tipex!
LOL
Hardly a professional approach...Laugh
Posted 22nd Mar 2012 at 14:49
f**k tippex! just pin it properly.
and if it doesn't pin, common sense would dictate that the pulley is donald ducked...
aaron6
stan_306gti6 wrote:
aaron6 wrote:
Tipex!
LOL
It has its merits though. Good checking method though. Done it on the zx. Wink
Posted 22nd Mar 2012 at 15:11
CammyDudge*
well if i get the right offer I will let it goThumbs up
CammyDudge
Posted 22nd Mar 2012 at 18:53
darkgti6
roland rat wrote:
aaron6 wrote:
Isnt the nation reason for mistiming the engine and causing a tap caused by a knackered crank pulley? Of so, people should factor it in and should have nowt to worry about.
nah can be mis-timed cam pulleys also.
How do people get this wrong? I worried about doing mine for ages then just got stuck in. Pinned the cam pulleys and crank pulley, changed the belt, rotate engine by hand a few times, pin it again, all good, job done????
Team Peugeot Sport 308 Gti�
Posted 22nd Mar 2012 at 21:05
Post #35
Yes, its not difficult. However, if you haven't done this sort of thing before I guess it can be a bit daunting. Its not that hard to screw up and unfortunately plenty of people have done it. Sad
Posted 22nd Mar 2012 at 21:13
darkgti6
Post #36
Stan - when tensioning the belt what sort of tightness do you aim for around tensioner pulley 'g' in the pic. Should the belt be tight enough so that the back of the belt grips it or looser so it can be rotated by hand when the belt is tensioned?
Posted 22nd Mar 2012 at 21:26
Post #37
I don't really check that to be honest mate.
General rule of thumb is to have the belt tightness between the 'G' pulley and the inlet pulley set so that forward to back movement is about 10mm and you can't twist the belt more than 90 degrees, but you should be able to twist it to that 90. Yes
Posted 22nd Mar 2012 at 21:30
Pages (2): 1 [2]
