Author Subject: what fuel pump question
mrdeey
It appears the fuel pump on my phase 1 low boost supercharged car is donald ducked , the part number on the bosch pump is 0 580 453 052 , should i just replace it or go for an uprated one , like maybe the walbro GSS 341 ,if it will fit of course , what has anybody else done?
now new booted , boosted and flying again!
Posted 17th Mar 2012 at 19:58
Simply replace it, no need for anything more.
Posted 17th Mar 2012 at 22:29
mrdeey
As phase 1 pumps are not that common and old ,just wondered what else might fit ?
Posted 18th Mar 2012 at 08:21
doesn't matter how common they are, just buy a new pump.
0580 313 109 is the part number for the phase 1 pump unit (superseeds 0 580 313 057 )
http://www.bosch-automotive-catalog.com
Posted 18th Mar 2012 at 09:18
mrdeey
Thanks for those part numbers , looks like it had the wrong one in it anyway , it had been replaced at some point with 0580 453 052 and that is out of a 106 !
Posted 18th Mar 2012 at 10:11
thats probably the bare pump unit itself, if you can find someone selling that on its on you should save some cash, Bosch dont list the bare pump for the 306.
Posted 18th Mar 2012 at 10:24
mrdeey
any way of cofirming the bare pump number welshpug ?
Posted 18th Mar 2012 at 10:31
none that I've found, you'd need to take apart a gti6 pump.
I wouldn't be surprised to see that the 106 uses the same pump, the superseded part number for a 205 is the same too, known to flow enough for mid 200's n-a.
looking at the 106 listing 0 580 453 052 was discontinued in 2004 and 0580314075 is the replacement.
apparently there's only 7 replacement pumps listed by bosch, to replace 72 different units.
http://www.bosch.com.au/content/language1/downloads/BOSCH_Fuel_Pump_WEB.pdf
Posted 18th Mar 2012 at 10:40
mrdeey
so its looking like the one in the saxo vts could be the same then , as i see it ?
Posted 18th Mar 2012 at 11:10
mrdeey
Put a new Walbro gss 341 in place of the original , and a replacement Bosch 3 bar regulator from a golf , now working fine
Posted 25th Mar 2012 at 11:54
pete-gti
How did you fit the gas 341 , its nothing like standard fitting ?
Posted 27th Jan 2014 at 23:10
I doubt you'll get an answer from him Pete - he's no longer a member. Sad
Posted 27th Jan 2014 at 23:41
pete-gti
Alright, shame wax going ask if he got bad fuel surges round corners, because bottom of the walbro doesn't interface with the OEM pick up in bottom of housing
Posted 28th Jan 2014 at 00:02
is yours just not an inline one rather than a pickup one?
Posted 28th Jan 2014 at 15:22
pete-gti
Yea different design to your one I'm sure of it,
Posted 28th Jan 2014 at 16:10
