Author Subject: Strange pull on deceleration
cornish_pug
Hi all, just this week the car has been pulling to the left when I ease off the throttle then when i accelerate it rights itself. What could this be? I did change the n/s wishbone today.
Team Diesel
Posted 16th Mar 2012 at 18:01
basically the rubber on your side is newer and stiffer so has less give, the one on the other side is older and has more. When you decelerate your putting weight on the bushes and the left one moves causing the right do be in front of it causing a steering effect.
IMO
Posted 16th Mar 2012 at 18:16
cornish_pug
It did it before I put the new wishbone on though.
Team Diesel
Posted 16th Mar 2012 at 18:24
Binding brake caliper ?
Posted 16th Mar 2012 at 18:26
Or tracking ?
cornish_pug
When i changed the wishbone I did notice the caliper was quite hard to open up.
I'll check them both properly tomorrow and free up if needed.
Team Diesel
Posted 16th Mar 2012 at 18:37
Snapped wishbone?
Posted 16th Mar 2012 at 18:49
cornish_pug
daveyboy wrote:
Snapped wishbone?
n/s wishbone is new & o/s wishbone is still solid.
Team Diesel
Posted 16th Mar 2012 at 18:50
lose track rod end? apparently mine was loose once sfter i hit a cats eye on the motorway and i had similar symptoms
Posted 16th Mar 2012 at 19:35
cornish_pug
Ok I'll take a look at that to.
Team Diesel
Posted 16th Mar 2012 at 20:58
Rich E Forum Admin
Did you check the tightness of the wishbone bolts? I've had these exact symptoms caused by a front wishbone bolt coming loose.
Posted 16th Mar 2012 at 21:45
dan86
I had this. It turned out to be play in the nearside front wheel bearing. Changed this and it sorted it. Knackered p bushes will also make the car wander.
Posted 16th Mar 2012 at 21:58
cornish_pug
Yes I have checked, plus it was exactly the same before i changed the wishbone.
Team Diesel
Posted 17th Mar 2012 at 17:21
cornish_pug
Problem sorted folks, it was a loose track rod end.
Team Diesel
Posted 18th Mar 2012 at 12:27
