displaying posts 26 to 50 of 56
Pages (3): 1 [2] 3
Author Subject: Flat battery changed but now won't start! Key fob not workin
gb_gti6 wrote:
Is there an easy fix without buying an unlocked ECU if it this?
If it is this then you don't need anything more than a new fuse...
Posted 15th Mar 2012 at 22:31
gb_gti6
Oh yeah I meant if its not just the fuse. I will have a look tomorrow.
Thanks for help with this!!
Team OCD
Posted 15th Mar 2012 at 22:33
gman
Have you tried re-programming your key? Just a guess really- I think there is an FAQ on how to do it
1992 Onyx Black 205 GTI-6
2005 Honda S2000 (Sold)
2002 Audi S3 (Sold)
2005 Clio 182 Trophy (sold)
Posted 15th Mar 2012 at 22:37
gb_gti6
That's not an option but thanks
Team OCD
Posted 15th Mar 2012 at 22:41
The fact that the central locking is not working ALONGSIDE the car not starting tells me this isn't ECU related. I think its a simple fault.
If the ECU had gone bad, everything else electrical would still work, you just wouldn't have a running engine, but that isn't the case. Wink
Posted 15th Mar 2012 at 22:45
Have a good detailed check of all the fuses in the daylight, preferably by electrically checking them and then get back to us.
I am fairly confident this issue should be resolved with a bit more checking around. Yes
Posted 15th Mar 2012 at 22:51
gb_gti6
Back again!! The fuses are all fine and I have just checked and the central locking is working, just not when I use the key fob
Team OCD
Posted 16th Mar 2012 at 17:54
pebbles167
Is there a red button at the rear right (as you look at it) in the engine bay? If so depress that. Should do the trick Thumbs up
2005 Peugeot 206 GTI 180
2008 BMW K1200R
Posted 16th Mar 2012 at 21:12
gb_gti6
It's not that I have checked all the obvious things!!
Team OCD
Posted 16th Mar 2012 at 21:18
Post #35
Do you have a spare key you can try?
Posted 17th Mar 2012 at 00:42
gb_gti6
Post #36
No but this happened with another one I had and didn't matter which one I used. I think it is the immobiliser again!! Checked the live to the fuel relay and it drops out after about 5 secs same as before!
Team OCD
Posted 17th Mar 2012 at 17:50
Post #37
Does indeed sound like the immobiliser won't unlock on the ECU. Sad
Unlocked ECU may be the way to go now. It could of course be that the transponder aerial (the part which surrounds the ignition barrel) has gone bad, therefore it is not picking up the signal from the chip which sits within the key fob...
Posted 17th Mar 2012 at 19:32
gb_gti6
Post #38
I am thinking unlocked ECU again everything it's doing was the same as last time and ECU sorted so might have to go that way again!! Where's the best place to get one do u reckon, fairly strapped lol
Team OCD
Posted 17th Mar 2012 at 19:46
Post #39
PM a guy on here rich_w, he sells them. Thumbs up
Posted 17th Mar 2012 at 19:52
gb_gti6
Post #40
Sweet thanks for your help with this. Much appreciated!! How forums should be conducted!!
Team OCD
Posted 17th Mar 2012 at 20:13
Post #41
We aim to please...Wink
Posted 17th Mar 2012 at 22:27
Post #42
Any further forward with this yet? Unsure
Posted 21st Mar 2012 at 23:19
Post #43
Any result with this yet mate? Unsure
Posted 2nd Apr 2012 at 14:59
gb_gti6
Post #44
Not noticed these post, still not starting just waiting another ECU!! Did buy an unlocked ECU but didn't work but just waiting to get one off rich now!!
Team OCD
Posted 2nd Apr 2012 at 19:58
Post #45
Ok mate, keep us informed on progress. Thumbs up
Posted 2nd Apr 2012 at 23:18
gb_gti6
Post #46
Bought a rich_w unlocked ECU and staring now just the key fob that doesn't work!!
Team OCD
Posted 5th Apr 2012 at 16:14
Post #47
Good stuff, I wonder why the original ECU locked itself? Hmm
Glad you got it running mate, new battery in the keyfob now?
Posted 5th Apr 2012 at 16:39
gb_gti6
Post #48
Already changed the battery in the fob!! Yeah least it's running again, no idea what caused it to happen
Team OCD
Posted 5th Apr 2012 at 18:02
Post #49
Well, a good result none the less. Thumbs up
Posted 5th Apr 2012 at 23:05
gb_gti6
Post #50
Hi again, still can't lock the car!! Fob doesn't work and the ignition barrel has been changed so the blade doesn't work in the door locks. Is there any way I can get the remote fob working again without changing everything? Any ideas?
Team OCD
Posted 19th Apr 2012 at 20:30
Pages (3): 1 [2] 3
