Author Subject: over revving after fitting aftermarket back box
tony eastwood
Is this related? I've searched high and low for info.
Posted 13th Mar 2012 at 22:56
darkgti6
There wont be any information because the engines maximum rpm is limited by the ECU.
Team Peugeot Sport 308 Gti�
Posted 13th Mar 2012 at 23:38
By over-revving do you mean the engine now exceeds 7250rpm or do you mean the idle is too high?
Posted 14th Mar 2012 at 00:51
tony eastwood
It's revving when I press the clutch to change gear a little bit.
Posted 14th Mar 2012 at 10:08
anth
You sure your not just noticing it now that the exhaust is louder?
Posted 14th Mar 2012 at 10:34
ICV may need cleaning then...
Posted 14th Mar 2012 at 10:40
tony eastwood
No because it had snapped before I fitted the new one :S what's an icv?
Posted 14th Mar 2012 at 15:06
tony eastwood
Looked it up, I'll have a go at that. Thanks Smile
Posted 14th Mar 2012 at 15:08
swiftyboi006
Take it off and give it a clean this is what hapend to mine so i cleaned it now its ok Thumbs up
Black p3 Love
Posted 14th Mar 2012 at 16:26
Solved yet Tony? Unsure
Posted 15th Mar 2012 at 23:57
mattgti6phase2
Another vote for ICV. When they stop working they stay in the position it was last in. This would be in a retracted position therefore letting too much air through.
When they stick in the extended position it won't allow any air through so the car won't idle at all.
The best way to check is by removing the ICV whilst leaving it plugged in, Then get someone to turn the ignition to position 2 if the ICV is working then you should see it move into its desired position. If it does nothing then it's f**ked Thumbs up
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 17th Mar 2012 at 00:15
