Author Subject: Spark plug question (pic inside)
hsustyle
First of all,do these look fine? Colouring etc?
And secondly how do I adjust the new spark plugs?
Beef Beyond Belief
Posted 13th Mar 2012 at 14:31
They look ok to me. Smile
You don't need to adjust the new plugs as they are a dual-electrode design, just need fitting thats all.
Posted 13th Mar 2012 at 14:36
hsustyle
Cheers Stan!
Beef Beyond Belief
Posted 13th Mar 2012 at 14:49
yup, just a bit of copper grease on the threads and tighten as shown on the box Smile
the old ones look pretty good, one or two were a bit grubby before I changed the gasket etc.
hsustyle
This has sorted the misfire in high revs..
What are tell tell signs of la faulty ambda sensor? I get, boggy hesitant acceleration under 2k revs, poor idle and wants to cut out, not as much of a smooth powerband. Seems more rough and lumpy? Also feels down on power. Tends to do it more when warm.
Beef Beyond Belief
Posted 13th Mar 2012 at 17:27
They are the exact symptoms. Yes
Posted 13th Mar 2012 at 17:31
hsustyle
Phew! All sorted come tomorrow afternoon!
Beef Beyond Belief
Posted 13th Mar 2012 at 17:37
hsustyle
New lamda sensor fitted.its a lot better but still occasionally runs hesitant and jolty between 1000-2000 revs.
Also replaced spark plugs,coolant temp sensor,icv,tps and map sensor.
I have a seller later and kinda need to know what it is.plugged the car into diagnostics and it all checked out,not a single fault code..
Doesn't misfire, more feels like over fuelling and only after a long (hard) drive..
Beef Beyond Belief
Posted 17th Mar 2012 at 09:52
replaced the rad yet?
Posted 17th Mar 2012 at 10:02
hsustyle
Not yet.I have a new one on the way. Could that be it?
Beef Beyond Belief
Posted 17th Mar 2012 at 10:20
it does leak so it could be leaving an airlock in the cooling system confusing the temp sensor.
can;t think what else it could be IF the sensors were tested and known good.
Posted 17th Mar 2012 at 10:32
Try changing the power steering sensor bud - it sounds silly but I have seen them cause all sorts of funny running issues Yes
Posted 19th Mar 2012 at 22:17
car's gone LOL
Posted 19th Mar 2012 at 22:22
Feck it then Yes
Posted 19th Mar 2012 at 22:27
hsustyle
Thumbs up
bigbadbowen wrote:
Feck it then Yes
Beef Beyond Belief
Posted 19th Mar 2012 at 22:34
How much did you get in the end dude ?
Posted 19th Mar 2012 at 22:37
Well done on the sale, it probably wasn't what you wanted to do but I know you had problem after problem with it in the short space of time you owned it. Sad
Posted 19th Mar 2012 at 23:03
hsustyle
1650 with the Magnex fitted. Got a white 106 Gti now. Sooo much cheaper on fuel and a car that I can fix myselfSmile
Beef Beyond Belief
Posted 19th Mar 2012 at 23:05
