Author Subject: Passenger airbag
scotzman
Hi how do i remove the passenger airbag from the dash?
cheers
Posted 13th Mar 2012 at 13:45
eddy_gti6
You need to remove the head unit and through the hole to the left there is a i think 13mm bolt you need to remove then there is a catch you pull then you should be able to lift the air bag out.
Home that helps Thumbs up
Posted 13th Mar 2012 at 13:54
scotzman
thanks, found it myself Smile
Posted 13th Mar 2012 at 13:57
